Clarkie Posted November 21, 2011 Posted November 21, 2011 Just noticed earlier that my oil pressure was reading quite high. At around 2000rpm it's about 60psi but as you increase the revs it goes up to about 110+ psi at high revs. I've just changed over the air filter from a k&n back to the stock air filter as i need to sort a problem with the k&n. Could this cause the high oil pressure issue? Just had it serviced on Friday and it was running fine at the weekend when i went for a long run. Thanks Quote
Ekona Posted November 21, 2011 Posted November 21, 2011 I can't remember what the gauge reads between now, but oil pressure is related to how much oil you have in the sump as well (although it's not a reliable level indicator before anyone points that out!). I suspect you were fairly low on oil before and now it's been topped up after a service are just noticing the gauge reading a bit higher due to this. To put your mind at ease, changing the air filter will have no effect on this at all. Quote
Clarkie Posted November 21, 2011 Author Posted November 21, 2011 Ah that's reassuring, i didn't think it would affect it but one never knows! So reading 110+psi is perfectly acceptable and safe then? Quote
DoogyRev Posted November 21, 2011 Posted November 21, 2011 Thats normal as far as I know. I seem to remember reading somewhere that when your car is warmed up, if you drive at 60mph, in 6th gear the psi should read 60 or a little below. This seems to be true for my car, on a really long run on a hot day it may get as low as 50 psi. This also works for 30mph in 3rd, 40mph in 4th, and 50mph in 5th - should all read about 50-60 psi Quote
Watshot Posted November 21, 2011 Posted November 21, 2011 The oil pressure increases with engine speed, so assuming you have the correct level of oil, what you describe would appear normal. Although there is no indication of 'limits' in the handbook, and I can't say that I have glanced at mine when I have redlined it. Quote
tprice Posted November 23, 2011 Posted November 23, 2011 having oil pressure is good, its when youve got none you need to worry cause its mean your engine wont be lubricated and boooooooooooooooooooooooooooooooooom Quote
tprice Posted November 23, 2011 Posted November 23, 2011 well in actual fact it will be more like, tap tap tap tap seize Quote
Darren-B Posted November 24, 2011 Posted November 24, 2011 Has the correct weight of oil been put in? 30w? If a heavier weight of oil has been put in, say 40w the oil will be a thicker viscosity therefore resulting in higher oil pressure...... Quote
Dynamic Turtle Posted February 9, 2012 Posted February 9, 2012 Hmmm, pretty sure my oil gauge was reading 30-40psi the other day. Seems very low according to this thread. Weird, because it had a "full service" and MOT last week (albeit by a porsche specialist). Cause for concern? Quote
marzman Posted February 9, 2012 Posted February 9, 2012 Has the correct weight of oil been put in? 30w? If a heavier weight of oil has been put in, say 40w the oil will be a thicker viscosity therefore resulting in higher oil pressure...... +1. Also the current very cold temperatures might be adding to this... Quote
MidnightRacer Posted February 10, 2012 Posted February 10, 2012 Was the car cold or warmed up when you looked at it? Quote
cmck13 Posted February 10, 2012 Posted February 10, 2012 Perfectly normal see the links below. http://www.350zmotoring.com/forums/350z ... ormal.html http://www.youtube.com/watch?v=5lPWY1S4erg Quote
sasha@lazytrips Posted February 10, 2012 Posted February 10, 2012 Mine always reads quite substantially higher until the car is fully warmed up in the winter than it does in the summer. Perfectly normal. Quote
Dynamic Turtle Posted February 10, 2012 Posted February 10, 2012 Ok thanks for clearing that up Quote
stubzie83 Posted February 10, 2012 Posted February 10, 2012 Mine never seems to go above 90 PSI apart from the odd occasion when it has spiked up to about 110 PSI running 5W30. I always thought that the pressure relief valve must be set for around 90 PSI as this seems to be the point that it stops at independent of the engine rpm rising further. When it's cold mine usually sits at 90 PSI on high idle and drops off as the engine warms up and idle speed drops. Warm idle is usually about 20 - 30 PSI. I would have thought that too higher pressure would cause issues with oil seals and gaskets leaking. Quote
M13KYF Posted February 11, 2012 Posted February 11, 2012 10w40 is the recommended choice from abbey Quote
Dblock Posted February 12, 2012 Posted February 12, 2012 10w40 is the recommended choice from abbey hmm Ive been running 5-30 or 5-40 Quote
