RisingPower Posted May 1, 2011 Posted May 1, 2011 Now, I know berk hfc's have a reputation for cracking with the nismo y pipe and the flexis on my y pipes are looking a little scraped. That and the stock cats Question is, what should I get for a bit more noise without rasp? Apparently the motordyne xyz w/resonator is pretty good for drone/rasp, but I'd just be concerned about being pulled. Motordyne xyz w/race cats going to have any effect whatsoever on the rasp from unresonated test pipes? Or the somewhat cheaper option, just stick some berk hfcs on, but considering the marks my stock cats have on them (thought it was just the flexis scraping ), i'm not exactly sure how the berks would fare. Would be nice to have to worry less about scraping Quote
350 Russ Posted May 1, 2011 Posted May 1, 2011 the brks have a bracket on them so that the y pipe doesnt have to take any weight off of them i think Quote
RisingPower Posted May 1, 2011 Author Posted May 1, 2011 the brks have a bracket on them so that the y pipe doesnt have to take any weight off of them i think Mm but from what I've seen the nismo y pipe is also a bit shorter than the motordyne xyz and apparently that's another reason for the hfcs cracking. Quote
MWTech Posted May 2, 2011 Posted May 2, 2011 are you looking for the nismo exhaust exit too? if so.. viewtopic.php?f=140&t=47944 Quote
RisingPower Posted May 2, 2011 Author Posted May 2, 2011 are you looking for the nismo exhaust exit too? if so.. viewtopic.php?f=140&t=47944 Nah, sorry fella, trying to figure out which one won't kill my nismo/pee off rozzers and sound louder BTW you linkied the blitz nur Y back? Quote
The G Man Posted May 2, 2011 Posted May 2, 2011 Berks HFC's are a quality item, and the brackets put no strain on any other part, you won't regret it Quote
RisingPower Posted May 2, 2011 Author Posted May 2, 2011 Berks HFC's are a quality item, and the brackets put no strain on any other part, you won't regret it Yeah, the berks won't put strain on other parts, but i'm concerned the nismo y pipe will But now I've heard how raspy unresonated test pipes are, damn Quote
rtbiscuit Posted May 2, 2011 Posted May 2, 2011 the one thing i learned with tuning the NA zed is that you can spend a hell of a lot of money for not a lot of gain. if it was me going for maximum power i'd go with the xyz pipe as you can fit de cats and a resontated pipe for most of the year for maximum power and then pop a hi flow cat in 30 seconds for the mot. but for noise i think that a completely un resontated system sounds like arse. its not a racy rasp sound as rasp and race don't go together, rasp to me says poorly designed exhaust. so for best noise i'd be looking at something like the stillen y pipe i think tarmac was doing them berk hi flows, and something like an HKS exhaust. Quote
RisingPower Posted May 2, 2011 Author Posted May 2, 2011 the one thing i learned with tuning the NA zed is that you can spend a hell of a lot of money for not a lot of gain. if it was me going for maximum power i'd go with the xyz pipe as you can fit de cats and a resontated pipe for most of the year for maximum power and then pop a hi flow cat in 30 seconds for the mot. but for noise i think that a completely un resontated system sounds like arse. its not a racy rasp sound as rasp and race don't go together, rasp to me says poorly designed exhaust. so for best noise i'd be looking at something like the stillen y pipe i think tarmac was doing them berk hi flows, and something like an HKS exhaust. Stillen pipe has no flexis either AAM does though. Yeah test pipes with resonators with the xyz and race cats = $$$ Just doesn't seem worth it tbh. Not sure I fancy running without cats at all though. Oh and I think the nismo has a resonator in the mid pipe but that seems to do feck all Quote
spursmaddave Posted May 3, 2011 Posted May 3, 2011 Stop trying to make your Zed sound like a chavvy Corsa or Saxo You have a very nice exhaust that imo sounds just right, HFCs would make it a bit deeper without any extra drone Quote
RisingPower Posted May 3, 2011 Author Posted May 3, 2011 Stop trying to make your Zed sound like a chavvy Corsa or Saxo You have a very nice exhaust that imo sounds just right, HFCs would make it a bit deeper without any extra drone Yeah it's looking that way so far tbh Though there always is the option of just removing everything from the manifolds back. Open headers ftw Quote
Tarmac@TarmacSportz Posted May 3, 2011 Posted May 3, 2011 Stop trying to make your Zed sound like a chavvy Corsa or Saxo You have a very nice exhaust that imo sounds just right, HFCs would make it a bit deeper without any extra drone In all seriousness it's probably worth listening to a car that has HFCs. You tube is good for giving an idea but it doesn't compare to real life. Quote
Husky Posted May 3, 2011 Posted May 3, 2011 Though there always is the option of just removing everything from the manifolds back. Open headers ftw to give you an idea, this is the car with an open midpipe and this is it with an open y pipe Quote
Animal Posted May 6, 2011 Posted May 6, 2011 My exhaust is: Berk HFCs > Japspeed Y-pipe > Blitz Nur Spec-T. All of the rasp comes from the Y-pipe. If I had the chance to do it again, I'd prob. go for the XYZ. Quote
