glastoveteran Posted February 1, 2009 Posted February 1, 2009 Hi all, Zed has been left unused for a month or so and the battery is dead - won't unlock, no lights on dash etc. It jump started fine but only drove around for about 10 mins and so as a result it's dead again. Can I charge it by driving it for a good hour or will it need charging with a proper charger? It's a JDM by the way so I know it has the smaller battery. Cheers guys, Alex Quote
Beavis Posted February 1, 2009 Posted February 1, 2009 Would say it needs a proper charging. But imho your battery may be duff. I often leave mine for several weeks at this time of year and never have any problems with a flat battery. May be worth getting it properly tested. Quote
martinmac Posted February 1, 2009 Posted February 1, 2009 I would say the simple answer is yes but this is assuming the battery is ok and everything is working. If you can get to one of the franchises they normally do free battery checks. Quote
MITZ@CougarStore Posted February 1, 2009 Posted February 1, 2009 In all fairness, I would be inclined to buy a new battery, lomoto has written a good guide on which battery to get as a replacement, from memory it was the biggest battery he could fit, but do find his post to confirm this… Quote
MITZ@CougarStore Posted February 1, 2009 Posted February 1, 2009 As Matrin said above, go to either Halfords or Kwik Fit for a free battery test/check… Quote
BulletMagnet Posted February 1, 2009 Posted February 1, 2009 Another good idea is to buy an Optimate III if you are gonna keep your car in storage for an extended period of time. It keeps your battery charged and helps against sulfating. You can also attach a permanent connection that allows you to just plug-in the optimate whenever you need it. Got one on a Honda CBR600 and it fires up first time everytime when having been in storage. Oh, looks like there is a newer version out http://www.demon-tweeks.co.uk/products/ ... de=MTXOPT4 Quote
Trev-the-Rev Posted February 1, 2009 Posted February 1, 2009 Another good idea is to buy an Optimate III if you are gonna keep your car in storage for an extended period of time.It keeps your battery charged and helps against sulfating. You can also attach a permanent connection that allows you to just plug-in the optimate whenever you need it. Got one on a Honda CBR600 and it fires up first time everytime when having been in storage. Oh, looks like there is a newer version out http://www.demon-tweeks.co.uk/products/ ... de=MTXOPT4 I use one of these and it is one of the best purchases I've ever made. Quote
Stew Posted February 1, 2009 Posted February 1, 2009 I have a good trickle charger on my bike. I have a CTEK one.... Great bit of kit. Quote
Ian Posted February 2, 2009 Posted February 2, 2009 Hi all, Zed has been left unused for a month or so and the battery is dead - won't unlock, no lights on dash etc. It jump started fine but only drove around for about 10 mins and so as a result it's dead again. Can I charge it by driving it for a good hour or will it need charging with a proper charger? It's a JDM by the way so I know it has the smaller battery. Cheers guys, Alex My battery is dead again this morning, its only been 4 days since it was last used but I can unlock mine with the remote, the windows autodrop when I open the door & I have dash lights (Very faint but they are on) I've tried jump starting mine but with no success, mine is a uk car though. Dodgy battery or something else wrong with car? (it hasn't had a proper run out since early december ) Sorry for hijacking your thread but its better than starting a new one for a similar issue Quote
Trev-the-Rev Posted February 2, 2009 Posted February 2, 2009 Sounds like a duff battery Ian. Best to get it off the car and have it tested. Quote
Beavis Posted February 2, 2009 Posted February 2, 2009 Sounds like a duff battery Ian. Best to get it off the car and have it tested. +1 its dead. Quote
Martin W Posted February 2, 2009 Posted February 2, 2009 Hi all, Alex My battery is dead again this morning, its only been 4 days since it was last used but I can unlock mine with the remote, the windows autodrop when I open the door & I have dash lights (Very faint but they are on) I've tried jump starting mine but with no success, mine is a uk car though. Dodgy battery or something else wrong with car? (it hasn't had a proper run out since early december ) Sorry for hijacking your thread but its better than starting a new one for a similar issue 4 days is about how long it takes the heated seat to flatten the battery.... Quote
BulletMagnet Posted February 2, 2009 Posted February 2, 2009 Do the heated seats stay on even after the key is out of the ignition? Sounds like a duff battery Ian. Best to get it off the car and have it tested. And while your getting a new battery, you might aswell shell out for an OptiMate Quote
Martin W Posted February 2, 2009 Posted February 2, 2009 Do the heated seats stay on even after the key is out of the ignition? Yep - read the manual ( I didn't have to ) Quote
Ian Posted February 2, 2009 Posted February 2, 2009 Hi all, Alex My battery is dead again this morning, its only been 4 days since it was last used but I can unlock mine with the remote, the windows autodrop when I open the door & I have dash lights (Very faint but they are on) I've tried jump starting mine but with no success, mine is a uk car though. Dodgy battery or something else wrong with car? (it hasn't had a proper run out since early december ) Sorry for hijacking your thread but its better than starting a new one for a similar issue 4 days is about how long it takes the heated seat to flatten the battery.... I'll check that Its been nearly 2 months since it last moved so I'll probably need a new battery anyway. Its the original battery so its lasted 5 years Quote
Rob_Quads Posted February 2, 2009 Posted February 2, 2009 Do the heated seats stay on even after the key is out of the ignition? Yep - read the manual ( I didn't have to ) You sure? I have just read the manual and it does not say this. It only says * When your finished turn back to OFF * If you keep your heated seats on without the engine running you could kill the battery Doesn't say the seats stay on. More to the point I have just been away for 8 days from mine with them on and it started fine. Have done it before for 11 days too without any problem. As for the battery - if you have drained it you will have damaged it so i would recommend replacing it. EDIT: Having read the service manual heated seats are ONLY on with ignition. So leaving them switched on with the car off will NOT drain the battery Quote
Martin W Posted February 2, 2009 Posted February 2, 2009 Do the heated seats stay on even after the key is out of the ignition? Yep - read the manual ( I didn't have to ) You sure? I have just read the manual and it does not say this. It only says * When your finished turn back to OFF * If you keep your heated seats on without the engine running you could kill the battery Doesn't say the seats stay on. More to the point I have just been away for 8 days from mine with them on and it started fine. Have done it before for 11 days too without any problem. As for the battery - if you have drained it you will have damaged it so i would recommend replacing it. EDIT: Having read the service manual heated seats are ONLY on with ignition. So leaving them switched on with the car off will NOT drain the battery What year is yours. I'm as sure as can be coz i did it - then found a warning not toleave them on in my 54 plates manual. Seemed bonkers not to just put a timer in.... Quote
Rob_Quads Posted February 2, 2009 Posted February 2, 2009 Mines an 04 I have the wiring diag for the model and the heaters are relay switched with the Ignition switch - See attached No company would allow a car accessory with high current draw to be left on by default without the ignition on. Quote
Martin W Posted February 2, 2009 Posted February 2, 2009 Mines an 04 I have the wiring diag for the model and the heaters are relay switched with the Ignition switch - See attached No company would allow a car accessory with high current draw to be left on by default without the ignition on. Well mine drains if I leave the seat on..... 10 times this year till I discovered the inncuous switch was on when i replaced the battery. Makes me wonder if having the Pioneer wired in somehow bypassed the ignition.. hmmm!! Quote
Rob_Quads Posted February 2, 2009 Posted February 2, 2009 hmmm i wonder if you have somehow crossed the feeds. Might be worth doing some testing. Leave car off but seats on - see if they are warm then remove the head unit and make some more checks Quote
Chris`I Posted February 4, 2009 Posted February 4, 2009 I'm pretty damn sure my heated seats only come on with ignition. Cant check though as I dont have it atm. Probably missed something but what has your HU got to do with the seats? Quote
