Olly350z Posted April 8, 2025 Posted April 8, 2025 Evening everyone, Got a few questions I'd like to get answered before it becomes a mad panic. I've bought a set of Work CR Kiwami's titan ashed bronze, a Satin finish for my Nismo, and I've tried to get as much in place as possible. These are going to be summer / show wheels with the idea of swapping back to the standard rays over winter. So, spigot rings, check ✔️ Genuine Work steel wheel nuts, check ✔️ 4 new boots for the alloys, check ✔️ What I'd like to know is firstly, TPMS sensors. Is it worth getting 4 more for the new alloys to retain the TPMS system, and will these need coding? If so, any brand to go for and is this something any reputable tyre place can do? I'd like to keep things as stock as possible and avoid any flashing warning lights. Or do I just suck it up and ignore the light? How does this tie in with tyre valves? The works come with there own ryre valves, can I use them? Secondly, the satin finish. What's the best way to maintain these wheels and are there any donts when it comes to cleaning? Ive never had satin wheels before and don't want to damage the finish by using the wrong methods for cleaning Picture of wheels 3 Quote
davey_83 Posted April 9, 2025 Posted April 9, 2025 No idea re the tpms, can't wait to see them on. What tyre sizes did you go for? https://www.cleanyourcar.co.uk/gtechniq-c5-wheel-armour Quote
Coz@TORQEN Posted April 9, 2025 Posted April 9, 2025 You can reuse the ones from your current wheels or purchase new ones but they're insanely expensive and will need coding once fitted. The TPMS sensors are integrated into the valves so you either use the work ones supplied and put up with the warning light, reuse your current ones which would just be a case of fitting the valves from your old wheels which have integrated TPMS sensors or fork out a few hundred quid for a full new set of sensors. Personally, I'd go option two if you're not planning on using your old wheels, works out a lot cheaper and you don't have to faff about with getting them coded. Quote
Olly350z Posted April 10, 2025 Author Posted April 10, 2025 On 09/04/2025 at 10:43, davey_83 said: No idea re the tpms, can't wait to see them on. What tyre sizes did you go for? https://www.cleanyourcar.co.uk/gtechniq-c5-wheel-armour I copied the same OEM tyre sizes, so 245/40 front and 285/35 rear. One of the main reasons why I went for these was sizing, they are identical to the original Rays apart from the offset. I knew how the wheels would sit with my existing setup and have been very happy with the "flush" fitment. On the front I gained 5mm clearance, and on the rear I gained 9mm. I figured to the naked eye this would be nearly impossible to see. It all aided the decision knowing they'd go straight on, no rubbing or touching so I could still enjoy the car On 09/04/2025 at 16:11, Coz@TORQEN said: You can reuse the ones from your current wheels or purchase new ones but they're insanely expensive and will need coding once fitted. The TPMS sensors are integrated into the valves so you either use the work ones supplied and put up with the warning light, reuse your current ones which would just be a case of fitting the valves from your old wheels which have integrated TPMS sensors or fork out a few hundred quid for a full new set of sensors. Personally, I'd go option two if you're not planning on using your old wheels, works out a lot cheaper and you don't have to faff about with getting them coded. What happens if I don't fit the TPMS sensors and run the car? Just a blinking warning light while driving? Think I'll do option two and just reuse them, I'd like to retain the TPMS and I'll just relegate the old wheels to winter wheels and put up with the TPMS light then Quote
GranTurismoEra Posted April 11, 2025 Posted April 11, 2025 (edited) Flash flash, been through that lol...just transfer them. Easily done. Erm Satin, avoid waxes. Probably similar to Satin wraps or paints. Dont use special waxes. Soap and water. Edited April 11, 2025 by GranTurismoEra Quote
ilogikal1 Posted April 13, 2025 Posted April 13, 2025 On 08/04/2025 at 21:48, Olly350z said: Secondly, the satin finish. What's the best way to maintain these wheels and are there any donts when it comes to cleaning? Ive never had satin wheels before and don't want to damage the finish by using the wrong methods for cleaning Avoid polishing with abbrasives, otherwise nothing special required. Waxes / C5 won't affect the finish noticeably, at least not unless it's side-by-side with an unprotected section (which I'd advise against for more reasons than just looks) and even then it's not going to suddenly turn the finish glossy. If you are particularly worried about retaining the satin finish, I'd recommend either Gyeon Q2 Matte or Nanolex Si3D Matte - either would work well on wheels and are designed for a matte or satin finish. Quote
Keith D Posted April 13, 2025 Posted April 13, 2025 I've used Finishcare hi-temp paste wax on my wheels for donkeys years. As far as protection goes I've found nothing better. Quote
Olly350z Posted April 13, 2025 Author Posted April 13, 2025 35 minutes ago, ilogikal1 said: Avoid polishing with abbrasives, otherwise nothing special required. Waxes / C5 won't affect the finish noticeably, at least not unless it's side-by-side with an unprotected section (which I'd advise against for more reasons than just looks) and even then it's not going to suddenly turn the finish glossy. If you are particularly worried about retaining the satin finish, I'd recommend either Gyeon Q2 Matte or Nanolex Si3D Matte - either would work well on wheels and are designed for a matte or satin finish. What about the cleaning of said wheels, say using wheel cleaners like autoglym magma or clean wheels? Can you still aggitate with a brush? Would you mind linking any products? I know you're hot on your detailing so was hoping I might get a reply from you. This is my first time dealing with satin compared to gloss so I'm keen to try and learn as quickly as possible Quote
ilogikal1 Posted April 14, 2025 Posted April 14, 2025 You can clean as normal, same products, methods, etc. You're not going to do any damage agitating or washing as you normally would. It's just polishing that you need to adjust - and most people don't polish wheels anyway - even then it's just a case of not using abbrassive compounds. You can still "polish" with non-abbrassive paint cleansers, for example. You should avoid anything with fillers too, but nothing's got enough fillers in to make a satin finish truly glossy. If it were me - wash and decontaminate (i.e. fallout & tar removers as needed) as usual. You can use specailist matte shampoo (which may slightly prolong the coating's lifespan) and/or quick detailer if you want to. I'm not a huge fan of quick detailers in general and a normal shampoo won't really adversely affect anything so it depends on whether you want separate products just for the wheels or not. Coat: Nanolex SI3D Matte comes a set with panel wipe and is a case of applying the product and just keep spreading it. Or, IPA wipedown (or Gyeon Prep, or Nanolex Ex can be bought separately) and then Gyeon Q2 Matte Evo, which is the more traditioanl wipe on, buff off job but comes with Cure which can be used as a quick detailer after application of Matte. For maintenance, regular washing every couple of weeks should be sufficient to keep on top of things. Occasionally through some iron remover and tar remover at it when needed and then top up the coating once a year or so. As mentioned above, your choice of shampoo will make such little difference (so long as it's pH neutral - most good ones are) that Gyeon don't make a matte specific shampoo - they would recommend standard Bathe (not Bathe Plus) which is a good shampoo if you need something, but use up what you've got first. 1 Quote
