z32bolt Posted September 22, 2025 Posted September 22, 2025 On 27/03/2025 at 21:14, Keith D said: Took the car to Horsham for a remap today. Very pleased with the result, my bum dyno says the car feels sharper and more on it, and the torque I felt it had lost from fitting the HFCs is back. Obviously the max hp figures are a bit meaningless, but have included below anyway. I am led to understand a stock 370z on a dyno dynamics is around 240 whp give or take; so the HFCs, Invidia and MegaFlow panel filters plus the tune have added about +40 hp over standard which would put it somewhere around 370-380 hp. Seems about right. What on earth is going on between 5500 and 6000rpm? 1 Quote
Keith D Posted September 22, 2025 Author Posted September 22, 2025 56 minutes ago, z32bolt said: What on earth is going on between 5500 and 6000rpm? Horsham put it down to a glitch with the dyno, but it could also have been the wheels climbing the roller and jumping Quote
GranTurismoEra Posted September 24, 2025 Posted September 24, 2025 Air ride looks cool but not sure how it rides. Adjustable coilovers? Quote
Keith D Posted September 24, 2025 Author Posted September 24, 2025 (edited) TBH I've never fitted air ride, I've always gone with coil overs on previous toys and either had the cars lowered and mostly ended up bashing the heck out the front, or had them higher that I might as well have stuck with stock. Airlift isn't cheap either so if I end up making the wrong choice it's the thick end of £5,000. A set of Tein Flex Zs are >£1000. Edited September 25, 2025 by Keith D 1 Quote
z32bolt Posted September 27, 2025 Posted September 27, 2025 On 22/09/2025 at 19:40, Keith D said: Horsham put it down to a glitch with the dyno, but it could also have been the wheels climbing the roller and jumping Certainly a bit odd. Does the same thing on both runs by the look of it. I wonder if it’s transmission related. The AFR doesn’t do anything wonky. I wouldn’t have thought the car was climbing the rollers, it’s not like it’s big power turbo car that suddenly comes on power. Quote
Keith D Posted September 27, 2025 Author Posted September 27, 2025 There's no stutter on power, it's smooth as butter all the way to the red line. It's not caused by the car. 1 Quote
Keith D Posted November 6, 2025 Author Posted November 6, 2025 (edited) Thats my rainy weekend job sorted - Nismo mk1 full carbon wing from Torqen. The quality of the carbon is gorgeous and well worth the wait. Now I've just got to make my mind up between airlift v coilovers with air cups... Edited November 6, 2025 by Keith D 2 Quote
Coz@TORQEN Posted November 7, 2025 Posted November 7, 2025 Pleasure dealing with you, sir! As always ❤️ Send some fitted pics when you can and we'll get them shared on the socials. 1 Quote
Keith D Posted November 16, 2025 Author Posted November 16, 2025 (edited) It's a fiddly job joining the upper and lower parts of the wing together, but other than that its a good fit to the boot panel. Nismo mk 1 probably my favourite wing. Now need some smoked rear lights... Edited November 16, 2025 by Keith D 2 Quote
Olly350z Posted November 17, 2025 Posted November 17, 2025 Did you have to drill any holes on the underside? I've always wanted a MK1 spoiler on my Nismo but it means a lot of work Quote
Keith D Posted November 17, 2025 Author Posted November 17, 2025 (edited) 32 minutes ago, Olly350z said: Did you have to drill any holes on the underside? I've always wanted a MK1 spoiler on my Nismo but it means a lot of work Mine is a GT and it lined up exactly with the existing holes in the boot used for a GT wing. It was a very simple job - I reused the fasteners and added a strip of 3M tape around the edge. Not sure about a V2 to V1 Nismo change. Edited November 17, 2025 by Keith D 1 Quote
Keith D Posted November 19, 2025 Author Posted November 19, 2025 That's the next bit sorted 😁 2 Quote
Adrian@TORQEN Posted November 19, 2025 Posted November 19, 2025 Thank you, Keith! Will just ask GReddy to start cracking on that turbo kit then... 🤣 Quote
Keith D Posted November 19, 2025 Author Posted November 19, 2025 1 hour ago, Adrian@TORQEN said: Thank you, Keith! Will just ask GReddy to start cracking on that turbo kit then... 🤣 It's on the list... this toy really needs to go "tish" 😂 Quote
Keith D Posted November 30, 2025 Author Posted November 30, 2025 (edited) Spent the day mocking up the airlift boot build. Pretty pleased with the outcome. The whole lot will need to come out again for finishing / trimming in acoustic cloth. Kept the Bose for now, that will be another project. Edited November 30, 2025 by Keith D 2 Quote
ZaneDylan Posted December 2, 2025 Posted December 2, 2025 Looks class, big fan of keeping the boot useable, like you've done here Quote
Keith D Posted January 11 Author Posted January 11 (edited) I had flu over xmas and the car has sat untouched for a month, so decided to set to on the airlift and fit the front. Very easy to fit. I did ponder airline route for a while; there are quite a few videos on YouTube showing people routing then under the car, and one guy routing through the car, but very little detail. I decided to drill through the footwells in the corner, fit grommets and route behind the liners and into the car. Seems safer to me and a straight run from bags to valve. Very pleased with how to came out and I won't have to mess around getting then over and under and around the rear subframe. I'm planning to set about the rears next weekend. Photo if it helps anyone in the future. Edited January 11 by Keith D 2 Quote
Keith D Posted January 31 Author Posted January 31 (edited) Finished the airlift today, very happy with the results. Car needs a vacuum! I've played around with different ways to isolate the compressor vibration and what I've found works best is double isolation, and adding dead sheet to the wheel well: (waiting for the airlift isolators but I've temporarily used some soft springs to prove it) Edited January 31 by Keith D Quote
Keith D Posted January 31 Author Posted January 31 (edited) Atmospheric shot, I asked copilot to stick a photo of my car to an urban background! Edited January 31 by Keith D 2 Quote
Keith D Posted February 8 Author Posted February 8 Small mod, front and rear chrome and carbon effect badges from z1 store 1 Quote
Keith D Posted Sunday at 08:38 Author Posted Sunday at 08:38 Took this at Refuel Cullompton on Friday night. Next Sunday theme is JDM v German if anyone in the S/SW is interested in a meet. Quote
