350Z FACELIFT ROADSTER BREAKING FOR SPARES
 Share
2006 Nissan Facelift 350Z Roadster finished in silver with black leather interior breaking for spares.
REV-UP ENGINE:  CD009 GEARBOX:  RAYS:  BREMBOS:
LIST OF PARTS SOLD
REV UP ENGINE
R/H BI-XENON HEADLAMP
L/H BI-XENON HEADLAMP
BONNET
R/H FRONT WING
L/H FRONT WING
R/H LED TAIL LIGHT
L/H LED TAIL LIGHT
L/H DOOR CARD
KEYLESS ENTRY MODULE
BONNET HINGES
N/S/F ARCH LINERS
BOSE AMP (BEHIND SEAT)
REAR SHOCK LOWER BOLTS
FRONT BUMPER SLIDER BRACKETS
R/H EXTERIOR DOOR HANDLE
R/H POWER WINDOW MOTOR
O/S/R BUMPER SLIDER BRACKET
BATTERY EARTH STRAP
L/H WASHER COVER & JET
INTAKE AIRBOX COMPLETE
4 x RAYS INCLUDING TYRES
2 X REAR KIDNEY BRACKETS
1 X REAR "W" BRACING
1 X COMPLETE OEM EXHAUST SYSTEM
2 X CATS
1 X "Y" PIPE
1 X R/H DOOR/GLASS EXTERIOR MOULDING
1 X L/H DOOR/GLASS EXTERIOR MOULDING
1 X PAS PUMP
1 X MISHIMOTO FAN SHROUD ASSEMBLY
1 X L/H VLSD SHORT STUBBY
1 X VELCRO ROOF STRAP
1 X EVAP CANNISTER COVER/SHIELD
1 X FRONT NUMBER PLATE PLINTH
2 X  HANDBRAKE SHOE RETAINING KITS
4 X FRONT BREMBO CALIPER BOLTS
1 X CRANK POSITION SENSOR
1 X L/H FUEL DAMPER
1 X R/H FUEL DAMPER
2 X SILL FIXING KITS
1 X ANTENNA FIXING KIT AND AMP
1 X R/H DOOR CARD
1 X N/S/F SUSPENSION KNUCKLE AND BJ.
20 X LUG NUTS
1 X ROOF MICRO SWITCH
1 X FUEL TANK FILLER NECK
1 X BRAKE LIGHT SWITCH
1 X SPARE WHEEL AND TYRE
1 X JACK AND HANDLE
2 X COILS
2 REAR BREMBO CALIPERS
4 X FRONT BREMBO PAD SECURING PINS
1 X L/H POWER WINDOW MOTOR
2 X O/S/F DOOR HINGES
1 X 5TH BOW MOTOR FRAME AND WORM DRIVES
1 X CLOCKSPRING
1 X O/S/F HEADLAMP WASHER COVER
1 X O/S/F HEADLAMP WASHER PUMP
1 X WINDSCREEN WASHER BOTTLE
1 X O/S/F BUMPER REFLECTOR
1 X FRONT BUMPER
1 X R/H WINDOW SWITCH
4 X HANDBRAKE SHOES
1 X FRONT TOE EYE COVER
1 X OPEN/CLOSE ROOF SWITCH
1 X L/H OUTER DOOR HANDLE
1 X PETROL TANK
1 X AIR CON PIPE
1 X UPPER CENTRE CONSOL PLASTIC TRIM
1 X LOWER CENTRE CONSOL PLASTIC TRIM
1 X ABS TRIPLE FUSE
1 X ACC. PEDAL
1 X FUEL PUMP
1 X FUEL PUMP BUCKET
1 X N/S/F BREMBO CALIPER
1 X N/S/F FOOTWELL NET
1 X CD009 GEARBOX
1 X ROOF LATCH
1 X ROOF FRAME
1 X L/H ROOF DAMPER
1 X ROOF LATCH MECHANISM
1 X O/S/F LOWER SUSPENSION ARM
1 X CUBBY LID
2 X COIL PACKS
1 X N/S/F BI-XENON WASHER PUMP & JET
5 X REAR BUMPER CLIPS
1 X REAR BUMPER SLIDER
1 X MAT CLIP
2 X REAR BUMPER LIGHT UNITS.
1 X VLSD
2 X REAR KIDNEY REPAIR SECTIONS
1 X PAIR FRONT HEATED LEATHER SEATS.
1 X AIR CON CONTROL UNIT AND RIBBON.
1 X O/S/F WINDOW GUIDE AND MIRROR SEAL ASSEMBLY.
2 X DOOR JAM SWITCHES.
1 X N/S/F WIPER ARM COMPLETE
1 X COIL PACK
1 X DOOR ACTUATOR-CABLES-LOCK ETC.
1 X REAR SUB FRAME.
1 X STEERING RACK.
On 14/02/2021 at 17:51, ZMANALEX said:
2006 Nissan Facelift 350Z Roadster finished in KYO silver with black leather interior breaking for spares.
LIST OF PARTS SOLD
REV UP ENGINE
BONNET
R/H FRONT WING
L/H FRONT WING
R/H LED TAIL LIGHT
L/H LED TAIL LIGHT
L/H DOOR CARD
BONNET HINGES
N/S/F ARCH LINERS
BATTERY EARTH STRAP
Hi Alex,
Do you have the part I am trying to hunt down ref my post?
Paul,
Please drop me a PM and refresh me with what Roadster trim parts you require.
I will have all the trim parts in stock.
I also have a PAS pump in stock and associated new belts. :thumbs:
  • 3 weeks later...
21 minutes ago, leebottrill said:
Hi mate. My air conditioning unit is apparently not working. How much for this part?
also my wheel arches are starting to rust. Are these bonded to the car or can they be removed? (I’m a roadster)
Hi mate,
What year and model is your Roadster?
What air conditioning part do you require? (all in stock)
I stock repair sections for the Roadster rear arches, however for the fronts best just to replace the wings as they are not expensive.
Just drop me a PM if I can help further.
 Share
