Handling - Concern
N4eay
Hi all,
Looking for some advice.
Car details are - 313HR - 37k miles, standard suspension with 20/25mm spacer setup.
Over the last couple of months I have noticed the following.
When going quite fast 80+ in a straight line, the front end seems to feel a bit vague / loose, also when cornering over rutted tarmac surfaces the front seem to jump / move around more than it should / use to.
Things that maybe contributing to this in my view:-
  • I have been told by the guys at Horsham Dev and the MOT report that the compression are bushes are starting to de-laminate, no knocking at the moment.
  • Rear tyres are 6 month old Goodyear Eagle F1's
  • Front tyres are 4 year old Bridgestone RE050a - no advisory's picked up by MOT.
I'm guessing that it may be a factor of old tyres and worn bushes, but maybe not.....?
Cheers
Nick
Thanks, was thinking about taking the spacers off, but hate the look after. Can't justify some 19". Would leaving the spacers on the rear and taking the fronts off then doing an alignment be stupid? I could live with the fronts not having spacers......
I don't think the Z looks too bad at standard height without spacers. I do agree when lowered the wheels tuck way too much.
I think leaving just the rears on might look a bit silly in all honestly.
When my front tyres were getting low I found my 313 HR was all over the shop, especially on roads around town. The steering felt really horrible, the car was trying to follow the camber of the road. Once I had new tyres fitted, the difference was amazing. I went for the same make/model (falken 452) tyres so it was just old tyres vs new.
Have you checked the tyre pressures are correct?
Spacers are not going to be connected with the issue you have, but a 4-wheel alignment may be a good idea.
Have the Horsham guys tested the car? If not then I suggest you get them or another specialist to do that before potentially spending money on things that don't need changing.
