Harryjax Posted April 10, 2015 Posted April 10, 2015 (edited) Any one know the torque setting for wheels on a 370. Edited April 17, 2015 by Harryjax Quote
GMballistic Posted April 10, 2015 Posted April 10, 2015 Apparently it should be 80-85ft/lbs. Source: http://www.the370z.com/wheels-tires/74998-wheel-nut-torque-specs.html I'd do it to 85ft/lbs same as 350Z though if it was me. 1 Quote
Naildialzed Posted April 10, 2015 Posted April 10, 2015 Any one know the torque setting for wheels on a 370. 115 Newton meters or 85 lbs per foot mate 1 Quote
Harryjax Posted April 17, 2015 Author Posted April 17, 2015 I need another torque setting this time for the rear hub nut. The big one with split pin Quote
ZMANALEX Posted April 17, 2015 Posted April 17, 2015 It is nice to say thank you to contributors for technical information provided. Quote
ioneabee Posted April 17, 2015 Posted April 17, 2015 thankyou .....................oh, you mean the OP 1 Quote
ZMANALEX Posted April 17, 2015 Posted April 17, 2015 Guess that will have to do then: 206 - 274 N·m (21 - 27 kg-m, 152 - 202 lb) 1 Quote
ioneabee Posted April 17, 2015 Posted April 17, 2015 trowbridge is only up the road from where I am this week - I'll ring something out of him ...................if I can find him Quote
-Bradders- Posted April 17, 2015 Posted April 17, 2015 just me that does the wheels up until there tight? Quote
Harryjax Posted April 17, 2015 Author Posted April 17, 2015 It is nice to say thank you to contributors for technical information provided. For the last setting you posted I pressed the like button same for the others that posted. But your right manners cost nothing. So thanks. Now I've grease all over my phone so thanks for that also Quote
Harryjax Posted April 17, 2015 Author Posted April 17, 2015 trowbridge is only up the road from where I am this week - I'll ring something out of him ...................if I can find him More than welcome to visit for a cuppa or a beer. Quote
ioneabee Posted April 17, 2015 Posted April 17, 2015 heading home tomorrow mate ........... otherwise might have done Quote
GMballistic Posted April 17, 2015 Posted April 17, 2015 (edited) just me that does the wheels up until there tight? Tight to you might be loose to somebody else though. Always best to follow the manufacturers torque settings for things like this. Edited April 17, 2015 by GMballistic Quote
ilogikal1 Posted April 18, 2015 Posted April 18, 2015 just me that does the wheels up until there tight? Tight to you might be loose to somebody else though. Always best to do things properly instead. Fixed that for you. 1 Quote
RobPhoboS Posted April 18, 2015 Posted April 18, 2015 just me that does the wheels up until there tight? Tight to you might be loose to somebody else though. Always best to follow the manufacturers torque settings for things like this. There are torque settings for a reason. Stuff that's been over tightened on my car has just snapped when I've undone it, or loose which is just as bad or dangerous. If you work on the car it's worth having a low-torque wrench as well as a bigger one for wheels/suspension etc. It's not expensive to do it properly. Quote
GMballistic Posted April 18, 2015 Posted April 18, 2015 just me that does the wheels up until there tight? Tight to you might be loose to somebody else though. Always best to do things properly instead. Fixed that for you. Cheers Matt. Needed doing really. 1 Quote
