Hi All,
Now that I own a 350, it has obviously become my pride and joy, however, one thing I am still trying to get to grips with are the gear changes. When I first drove it, I noticed that changing gear felt very mechanical, which I have no problem with at all. But it is very different to previous cars I have owned and has made me rethink my gear changing techniques. For a start there's getting used to short shifting and I also find myself being overly gentle with the gear changes. I expect I am over analysing it, but could really do with a few pointers. I'm not the greatest driver in the world, I will admit, but I would at least like to drive my 350 in the right way, if you know what I mean.
Thanks.
Posted (edited)
Gears are a bit different on a Zed ... be gentle when cold then treat it like a rifle when hot
ETA you'll get a few funny noises but you will not break it !!!
Edited by ATTAK Z
The gear box on the 350z is known for being heavy especially from 2nd to 3rd, it gets better once warm
Agreed - although with mine it's 1st to 2nd when cold. Once warmed up though things are smooth. Mechanical, but smooth.
Posted (edited)
Change the clutch line for a braided one aswell while your there and replace the clutch/brake fluid with high temp stuff
The braided clutch line comes as part of the packet if you change the clutch slave cylinder
from Clarks / Alex, this doesn't help with the notchie change from 1st to 2nd.. :thumbs:.
Edited by WhackyWill
I didnt change the slave just the line, it will take higher temperatures and wont expand like the oem line for a more consistent change when track driving
For 20 quid be rude not to while your there imo
Does the braided clutch line make a noticeable difference? Did the brake lines last week and I've got some Motul RBF 600 left so may do the clutch line too.
My box used to be a tad notchy from 2nd to 3rd even after I changed the gearbox oil (genuine nissan sports oil) and added moly slip, but once the hel line went on with the new ate superblue fluid it went, so yeah I think it has made a difference plus round the ring in June it was a pleasure to drive and work with
well worth the extra 20 quid for doing ot properly
