350Z - Has anyone please got any cheap tips to moderise?
timb2010
Hi all,
Just got my 350z, very happy.
I was just wondering if there was a suggested list of parts that can be straight swapped/replaced to modernise the look?
Ive looked at the following....
1) Replace the wipers with the new flat type? £10
2) Stubby Honda S2000 aerial £15
3) Replace the orange reflectors in the side of the bumpers with clear or colour coded. £25
4) LED Bulbs? Cant these be used if so where?
Are there many others that anyone could please suggest?
Thanks in advance!
Hi all,
Thanks in advance!
As for LED bulbs, you can get them in the side repeaters and sidelights (both W5W bulbs) Reverse and fog lights (T20 irrc, buy them both white, the fog light has a red filter in the bulb housing) and that's about it.
I tried many types of bulbs but I cant find any that fit into the very small holes/tight spaces for the indicators on the front or rear of the zed, have to stick with standard bulbs for these sadly.
Then buy some newer style LED rear lamps and you're all set. On a separate note, you can (as I have) upgrade the internal dome light and the vanity mirror bulbs all to LED too.
Haha !
I've yet to get it through the MOT !
But could I please have a price on the stubby and reflectors?
I've seen some on eBay for 17, 22 and 40 ! They all look the same! Are the ones you sell the best of the bunch?
Thanks for your reply
Cheap is fine but try to get proper surface mount versions rather than the bulb shaped ones, when you buy the sidelights & indicators try and get a pack of 5-10 as a few will probably blow. I bought 3x packs of 2 and 3 of them blew before I found two that lasted more than a few weeks, they have been on the car for 6 months now :)
Sidelights: http://www.ebay.co.uk/itm/10x-White-T10-SMD-1W-w5w-501-194-Car-LED-Licence-Plate-Side-light-Bulbs-UK-STOCK-/380694523294?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item58a3296d9e
Indicators: http://www.ebay.co.uk/itm/2-x-5-SMD-LED-ORANGE-AMBER-INDICATOR-SIGNAL-TURNING-SIDE-LIGHT-BULB-T10-W5W-501-/221051697118?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3377b537de
With the reverse/fogs, these are great as the lens sends plenty of light backwards whilst the sideways LED's make sure the cluster is illuminated fully. http://www.ebay.co.uk/itm/2-Pcs-White-T20-CREE-5-LED-Car-Canbus-Light-Lamp-Bulb-4W-12-24V-/370733963858?pt=LH_DefaultDomain_3&hash=item5651775a52 the only downside is theyre not cheap.
As for the dome lights These work great http://www.ebay.co.uk/itm/10x31mm-6-SMD-3528-LED-Car-Interior-Festoon-Dome-Pure-White-Light-Lamp-Bulbs-12V-/111138704574?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19e0620cbe and the sun visor bulbs are a bit harder to acquire, but these are what I have http://www.ebay.co.uk/itm/WHITE-Festoon-29mm-Fuse-bulb-3-SMD-LED-Sun-Visor-Vanity-Mirror-Light-6641-6614F-/200939861663?pt=AU_Car_Parts_Accessories&hash=item2ec8f2f69f There seems to be some Hong Kong sellers selling these now too, but cant comment on those since I havnt bought them.
I also sell LED front reflectors in black or clear :Dhttp://www.350z-uk.com/topic/70643-350z-de-drl-reflector-leds-gauging-interest/
Just 2 notes however. The resistance of LED's are a huge amount lower than the standard bulbs, the LED's in the dome light will stay dimly lit (can only be seen at night time) at all times. This has practically zero effect on the car however with my car sometimes being stood for 10 days without moving and it fires up perfectly every time.
Second, be VERY careful inserting the bulbs into the dome light clips. If you short circuit them you could damage the BCM. Just line the bulb up and press it into the clips in one nice movement, try not to let it keep tapping the clips.
And definatly get the stubby aerial from Tarmac, don't bother with the eBay versions, you will end up with a good looking aerial that cant pick up any radio stations.
Edited by cs2000
Haha !
I have one set of genuine nissans at £40
or Replica one at £25
Stubbies £15
If you want replica reflectors and stubby you can have them both for £38
