ecousi Posted April 4, 2013 Posted April 4, 2013 HI everyone thanks for looking at my post, My engine light is doing my head in!! it has been in to a Nissan dealer to have the fault code read and diagnosis but we are not getting anywhere. Has anybody else had this code P0430 TW Catalyst SYS-B2. The first time the light came on the code was P0420 TW Catalyst SYS-B1 (drivers side bank) so the dealer advised replacement of the rear 02 sensor on that side. This was completed and for a while the light was off, however now every time I do any motor-way driving Constant speed around 3000 RPM the light comes back on and the SyS - B2 fault code is displayed. the light does not go out with restarting the engine but is on all the time until I go into the dealer to have it turned off. Can anyone help?? I have a feeling that one of or both the cats are at fault but with new cats at £1500 each dont want to make a very expensive mistake, (the dealer has advised that the cats need to be replaced and then possible further testing) I am also concerned that this fault may be with the engine and may just knacker new cats in a short space of time. Any thoughts or ideas welcome!! Sorry forgot to add the engine is running fine with no hesitation or missfire. Thanks for reading Ed Quote
glrnet Posted April 4, 2013 Posted April 4, 2013 You'll pick up a set of cats on here for a lot less than that. Quote
Darren-B Posted April 4, 2013 Posted April 4, 2013 I have a brand new in the box never fitted set of BERK HFC`s for sale, been meaning to put a thread up for the last 6 months Quote
ecousi Posted April 4, 2013 Author Posted April 4, 2013 Hi Darren b sounds good. Will the HFCs cause the mil light to come on? Quote
Keyser Posted April 4, 2013 Posted April 4, 2013 You will need O2 spacers to stop the warning light with the Berks about £20. And along Quote
KyleR Posted April 4, 2013 Posted April 4, 2013 I have a brand new in the box never fitted set of BERK HFC`s for sale, been meaning to put a thread up for the last 6 months £50? Quote
Sam Mcgoo Posted April 5, 2013 Posted April 5, 2013 The cats/o2 sensors could be on the way out, but this is a fairly common problem especially when it is very cold. It is not a code that will do any harm to your engine, so don't worry about that. You can read / reset the codes yourself to save yourself some cash. 1. Buy yourself a cheap OBD2 reader from ebay (about £20) or a bluetooth one and get an app for your android phone called 'Torque' (I think there is a similar Apple app) 2. Do the 'Peddle dance' as follows: Confirm that accelerator pedal is fully released, turn ignition switch “ON†and wait 3 seconds. Repeat the following two procedures quickly five times within 5 seconds: Fully depress the accelerator pedal (HARD). Fully release the accelerator pedal. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking. Fully release the accelerator pedal (while the CEL is still blinking) Wait about 10 seconds. - Count the flashing lights now- this is the code. Fully depress the accelerator pedal and keep it for more than 10 seconds. Fully release the accelerator pedal (The CEL light will continue to blink). Turn ignition switch to “OFF†position and now you can start the car. The CEL light should be gone. There is a full guide in the guides section on here. If you want to try oem cats, PM zmanalex as I'm sure he'll have some good used ones for a good price. Or, use it as an excuse to buy the HFC and get a uprev to reap the benefits. Quote
ecousi Posted April 5, 2013 Author Posted April 5, 2013 Cool thanks everyone for the info and great advise. Darren B yes sounds good how can we sort out money delivery etc where abouts are you? could I collect? Where can I get some spacers for the sensors ? And finally just to confirm is the uprev an ECU remap ? and how would be the best people to carry it out ? Thanks again for all your help guys Quote
KC350Z Posted April 5, 2013 Posted April 5, 2013 for parts yes uprev ecu remap and if upreved you wont need spacers as it clears the fault there are a few that do uprev on here depending where you are abbey/rs/HD Quote
KC350Z Posted April 5, 2013 Posted April 5, 2013 look up abbey sub forum he has done a few write ups about what up rev does Quote
ecousi Posted April 5, 2013 Author Posted April 5, 2013 HI forgot to add the engine in my Zed is the later version with twin intake think they call it the HR. Will the HFC's still work with that Darren-b Thanks Quote
KC350Z Posted April 6, 2013 Posted April 6, 2013 yes sure will but make sure you tell them you have the hr 313 as I think they are different fit for earlier ones Quote
dave_c Posted April 21, 2013 Posted April 21, 2013 You could just get a code reader and turn it off every now and again Quote
nissan_pip Posted April 21, 2013 Posted April 21, 2013 ecousi where about in the country are you ?? Quote
Genecra Posted 21 hours ago Posted 21 hours ago I had this code on 370gt(g37) 2009, and it went through different shops that couldn’t sort it and costed an arm an a leg for fk all. I just end up buying some aftermarket cats, when the shop was going to install the cats they found a sensor on the inside edge of the exhaust manifold was blown out of its socket. I didn’t even know there was a sensor in there neither did the shops. Could be that Quote
