Mooresy14 Posted February 12, 2013 Posted February 12, 2013 Alright peeps. My boot won't stay up, has anyone had this problem and is it expensive to fix? Any help would be much appreciated. I'm thinking there are hydraulics in the boot, am I right? Â Cheers Mooresy Quote
Paddy78 Posted February 12, 2013 Posted February 12, 2013 Sounds like one or both of the gas struts is shagged (Technical term). You can get the re-gassed or get new ones. I don't think it's an expensive job and is easy to DIY (Did our Focus a few years back and it was a 10 min job). Â as he probably will have some! Quote
wizard Posted February 12, 2013 Posted February 12, 2013 My boot lid has hit my head so many times and it hurts!!! Quote
WhackyWill Posted February 12, 2013 Posted February 12, 2013 There are a few posts on here about them. Look it up on the Forum.. Easiest and cheapest solution is to remove the counter weight in the boot lid, this will lighten the boot, this problem happens when the weather is cold. You can replace them for a upgraded boot strut for about £30 per side, best to do both sides. Good Luck. Quote
Mooresy14 Posted February 12, 2013 Author Posted February 12, 2013 Cheers dudes. Think I've found something about a company called SGS On here.... Quote
wizard Posted February 12, 2013 Posted February 12, 2013 Cheers dudes. Think I've found something about a company called SGS On here.... Â You want to share that info? Quote
WhackyWill Posted February 12, 2013 Posted February 12, 2013 SGS do new uprated ones, they seem very good and easy to fit. I would just remove the weight in the boot lid 10mins job and save money. Quote
FUG Posted February 12, 2013 Posted February 12, 2013 Email breakers or put a wanted ad on here, i got a set for £25 off a member on here  SGS do uprated ones but bit more pricey and not sure what fitment is like? Quote
BulletMagnet Posted February 12, 2013 Posted February 12, 2013 I got a pair from SGS, new replacement non uprated for £65 posted. Dead easy to fit and the boot stays up like a pensioner that's had a dozen Viagra. I also suggest that when fitting to do one at a time so you don't install the bracket upside down by mistake Quote
KyleR Posted February 12, 2013 Posted February 12, 2013 I have the SGS engineering ones too. The fitting is perfect and they work well. Get the updated ones just incase you want to fit a spoiler some time, they're only a few quid extra. Also note the price they list is excluding VAT, think mine cost me £72 delivered but that's cause I'm in Nirthern Ireland. Quote
CrustyCrab Posted February 12, 2013 Posted February 12, 2013 SGS ones are easy to fit, only problem you may have is removing the ball studs from the OEM struts. I had to cut mine off but be really careful not to cut into the ball stud. Also helps if you remove the studs with the strut still attached if you find it too difficult to remove the strut whilst attached to the car.  Don’t forget to prop the tailgate open as it is quite heavy and I removed the boot plastic floor panel so I didn’t damage it. Quote
Mooresy14 Posted February 12, 2013 Author Posted February 12, 2013 http://www.sgs-engineering.com/gas-struts/car-boot-tailgate/nissan/350z/nl1749-nissan-350z-tailgate-boot-strut  Â£24 each? plus delivery so about £52? Quote
BulletMagnet Posted February 12, 2013 Posted February 12, 2013 (edited) Add vat too but yeah that's them. Think I paid more cos I went for next day delivery. I called them up to order, just to make sure I got a pair, just in case the brackets were different for each side. Edited February 12, 2013 by BulletMagnet Quote
Mooresy14 Posted February 12, 2013 Author Posted February 12, 2013 Standard ones or the Nizmo uprated ones? Quote
BulletMagnet Posted February 12, 2013 Posted February 12, 2013 I went for standard one, because I don't have a mahoosive spoiler that needs propping up, also have the boot weight removed. When I phoned up to order, the lady did say that if I did decide to fit a spoiler, I could always send them back to have the pressure upped, for a small fee of course Quote
Mooresy14 Posted February 12, 2013 Author Posted February 12, 2013 Ah ok cool thanks man. What does the weight in the boot actually do then? If you take it out does it affect the driving at all being RWD?  Yep in total, £65.76 wih VAT and delivery.... Quote
Voodoo Vix Posted February 12, 2013 Posted February 12, 2013 I got the uprated ones from SGS, in case I got a spoiler, and now I can just about shut the boot they're that much stronger and that's with the weight still in there lol Quote
Mooresy14 Posted February 12, 2013 Author Posted February 12, 2013 Well I might as well get the uprated ones as you get free delivery on over £66 and this now comes to £67.  Plus I might get a spoiler one day.... Quote
Watshot Posted February 12, 2013 Posted February 12, 2013 (edited) The weight is added to make it easier to close the lid, so that it catches first time, without having to put a lot of effort into it. Ironically, the Zed often struggles to lift the lid clear of the catch as the spring assistors fail and the gas struts age, the result being that removing the weight can help with opening. Â It no more affects the driving than putting any other item in the boot space, we're not talking about a massive amount of weight, just something to help overcome inertia. Edited February 12, 2013 by Watshot Quote
Mooresy14 Posted February 12, 2013 Author Posted February 12, 2013 (edited) Yeh mine doesnt stuggle to shut but does struggle to open first time. Â undecided as to what ones to get though...I probably will get a spoiler but not for a few months. Â edit - screw it, I wont be getting a spoiler for a while so I have just this minute bought the standard ones, should get them tomorrow. Edited February 12, 2013 by Mooresy14 Quote
Sam Mcgoo Posted February 13, 2013 Posted February 13, 2013 +1 for SGS Â I fitted the up-rated ones a couple of weeks ago, work brilliant. Â On a side note, I cant believe how heavy the tailgate is!!! Only removed them one at a time but could only just lift it. Quote
wizard Posted February 13, 2013 Posted February 13, 2013 (edited) +1 for SGS Â I fitted the up-rated ones a couple of weeks ago, work brilliant. Â On a side note, I cant believe how heavy the tailgate is!!! Only removed them one at a time but could only just lift it. Â Sam, Is it worth removing the tailgate if you fit the uprated ones? Like with the tailgate removed and you press the boot release catch, does the boot go up by itself? lol Edited February 13, 2013 by wizard Quote
KyleR Posted February 13, 2013 Posted February 13, 2013 Boot still doesn't clear the latch in its own with unrated if it didn't before, search the 2 pennies trick or pennies trick, can't remember which it is.  They also come with a fitting kit, ie. new ball joints so no need to cut anything.  Personally for the sake of about £5 a pair, there's no reason not to go updated. Quote
