C.J Posted May 28, 2012 Share Posted May 28, 2012 I drove 30miles yesterday, and when arriving at the top of a multi story car park, my temp gauge was maxed out, and the engine was showing white smoke. Upon pulling over and checking the bonnet, I could see coolant overflowing from the overflow pipe in the bottle.  I let the car cool down for an hour and topped up the coolant. I checked the fans, and neither were working. I turned the AC on, and no fans came on (I thought a fan should come on at all times with AC?). I took it to the nearest Kwik Fit (ssshhhhh) who thought my AC may have been empty and causing the fans not to kick in, so they regassed it for me, still no AC, but they didn't charge me.  I've done the 10button door switch test (wipers/lights/fans) and they either don't spin at all, or one each randomly.  Today I've taken the car out, and as the temp increased again (at standstill after 20miles) the fans didn't kick in.  The symptoms:  1. No AC (but full with no leaks) 2. No fans 3. Overheating  The possibilities are (from my research online):  1. Thermostat (but would this cause the fans and AC not to spin?) 2. Fans, fan motors, fan clutch? 3. Head gasket (Kwik Fit checked for this, no sign of it, so highly doubtful) 4. Radiator 5. Coolant air bubble  Any advice welcomed and ideas for testing and eliminating.  Also, I'd like to say thanks to a fellow 350z owner who did stop and check I was ok.  A picture of mine for the rubber neckers  Quote Link to comment Share on other sites More sharing options...
ianphampton Posted May 28, 2012 Share Posted May 28, 2012 Not going to be much help tracking the fault I'm afraid - but when mine did this about 2 years ago I had it checked over by the local garage and they said thermostat OK etc, it was the fans which weren't working.  Trying to buy fans from a breaker in a limited time proved unsuccessful, and I ended up paying £600 for the unit (2 fans mounted on the whole section from behind the radiator,) plus fitting - all at Nissan Stealers rates.  I had to pay it as I needed the car and didn't have the time to wait searcing all round for a second user unit -  I hope you have better luck than I. If not - prepare yourself for an unpleasant attack on the finances Quote Link to comment Share on other sites More sharing options...
notfub Posted May 28, 2012 Share Posted May 28, 2012 Pretty sure this is the fan motors.  Start the car and let it run for several minutes. Tap the centre of the fans (where the motors are) taking care to avoid the blades. If the motors are at fault they may well start after a sharp tap.  Alternatively, start the car, put the aircon on and tap the passenger side motor to see if it starts. I think the fan always kicks in when the aircon is on regardless of water temp.  My local dealer wanted £700 for the replacement fans, Zmanalex got them to me far cheaper. Fitted them myself, it's an easy job. I kept the old motors and will investigate re-conditioning them at some point, even though they are sealed units.  Good luck. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 28, 2012 Share Posted May 28, 2012 Sounds like it could well be fan motor failure.  In stock and good to go same/next day if required  viewtopic.php?f=157&t=48509  Alex Quote Link to comment Share on other sites More sharing options...
doctor austin Posted May 28, 2012 Share Posted May 28, 2012 Motors come apart easy.. the brushes get stuck and need dressing with a needle file..easy job Quote Link to comment Share on other sites More sharing options...
U83R5Z Posted May 28, 2012 Share Posted May 28, 2012 Motors come apart easy.. the brushes get stuck and need dressing with a needle file..easy job  Quote Link to comment Share on other sites More sharing options...
Dblock Posted May 28, 2012 Share Posted May 28, 2012 Hope you get it sorted mate. Quote Link to comment Share on other sites More sharing options...
C.J Posted May 29, 2012 Author Share Posted May 29, 2012 Thanks for the quick replies  I've dropped it off at my local Indy to double check for me, and I'll get a PM off to you ZMANALEX if it's the motors.  I'll update with my findings. Quote Link to comment Share on other sites More sharing options...
notfub Posted May 29, 2012 Share Posted May 29, 2012 Motors come apart easy.. the brushes get stuck and need dressing with a needle file..easy job  Can you expand on this please? Are you saying that you can "fix" the duff motors by using a needle file to file down something to ensure the brushes move more freely? Can't be that simple can it or it would be all over the forum? Quote Link to comment Share on other sites More sharing options...
C.J Posted May 30, 2012 Author Share Posted May 30, 2012 Ok, a quick update/question. Â The garage I dropped it off at on Tuesday, have told me today they've ordered a new 'temp switch'. Â Any idea what he means by this (thermostat?), and if this is likely to be the problem with my symptoms? Could the thermostat cause the AC not to work and fans not to spin? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 30, 2012 Share Posted May 30, 2012 Never known a temp switch to fail.  Plenty in stock if you wish to try one  Alex Quote Link to comment Share on other sites More sharing options...
C.J Posted May 30, 2012 Author Share Posted May 30, 2012 Never known a temp switch to fail.  Plenty in stock if you wish to try one  Alex  If it was the temp switch, what symptoms would I see? Quote Link to comment Share on other sites More sharing options...
JetSet Posted May 30, 2012 Share Posted May 30, 2012 Ok, a quick update/question.    Any idea what he means by this (thermostat?), and if this is likely to be the problem with my symptoms? Could the thermostat cause the AC not to work and fans not to spin?   Thermostats can fail in 2 ways, they can fail to open and overheat the car or they can stick open and the car will take an eternity to heat up especially in the winter. I can't see how either of these problems would cause the fans not to kick in though   Pete Quote Link to comment Share on other sites More sharing options...
trackpig Posted May 30, 2012 Share Posted May 30, 2012 Have the related fuses been checked? Â Turn the air con on full cold. Does fan run? Is there 12v across the fan electrical connector? Â These things need to be carried out before parts are ordered. Quote Link to comment Share on other sites More sharing options...
C.J Posted May 30, 2012 Author Share Posted May 30, 2012 I've no idea what's been checked. I'm adamant it's the fans at fault, hence the intermittent spins during my tests and AC not working. Â Would the thermostat cause the AC not to work too? Â Hopefully I'll get it back tomorrow, and will try some of your suggestions (tapping the fan when AC on). Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 30, 2012 Share Posted May 30, 2012 These schematics should help, however at the end of the day it will more than likely be the fan motors that have failed.  Any further questions, then just drop me a PM mate    Alex. Quote Link to comment Share on other sites More sharing options...
max Posted May 31, 2012 Share Posted May 31, 2012 It will be the fans very easy repair and Alex will be the cheapest place to buy, mine went two years ago bought two fans took about one hour to change and have had no problems since. max. Quote Link to comment Share on other sites More sharing options...
C.J Posted June 1, 2012 Author Share Posted June 1, 2012 Cheers. Â I've got the car back now. The fans are intermittently kicking in still, sometimes with AC, sometimes not at all. Â I'll do some tests over the weekend before deciding what to do. Quote Link to comment Share on other sites More sharing options...
C.J Posted June 20, 2012 Author Share Posted June 20, 2012 Can I have some more advice please  I still don't have the car back, and I've been told today that it's "both cooling fan resistors, need new, aprox £550 just for fans".  Does this sound right? If the 'resistors' have gone, I'll need new fans?  Moving house tomorrow, this is all I need. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 20, 2012 Share Posted June 20, 2012 New fan motors in stock and good to go same/next day  viewtopic.php?f=157&t=48509  Alex Quote Link to comment Share on other sites More sharing options...
C.J Posted June 20, 2012 Author Share Posted June 20, 2012 New fan motors in stock and good to go same/next day  viewtopic.php?f=157&t=48509  Alex  You're going to have to help me, he's quoted £550 for the fans (I assume this is 2 fans with 2 motors)  Your price is £200 per motor (£400 for 2). What's required to fit the motors to the fans, as the difference is £150. Quote Link to comment Share on other sites More sharing options...
C.J Posted June 20, 2012 Author Share Posted June 20, 2012 I've asked how much all in for fans/fitting.  I've just been told £1k. Seems steep? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted June 20, 2012 Share Posted June 20, 2012 The fan motors will take maximum of 1 hour to swop out.  You only have to replace the motors as your existing fans can be reused.  It is a very easy straight forward job  Alex 1 Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted June 20, 2012 Share Posted June 20, 2012 I've asked how much all in for fans/fitting.  I've just been told £1k. Seems steep?  Have you spoken to atkin666 he is a trader on here that is not too far from you I think, he might be able to give you a better price for fitting Quote Link to comment Share on other sites More sharing options...
C.J Posted June 25, 2012 Author Share Posted June 25, 2012 Update.  Long story short. Took car to Nissan in the end, £800 for fans/motors, fitted Friday.  Car is working as usual again Quote Link to comment Share on other sites More sharing options...
