SteveW Posted December 27, 2011 Posted December 27, 2011 (edited) Here you go folks. Please bear in mind all the precautions you should take when working with petrol. We do not want any accidents I would suggest you Start with just cleaning the pump sender and seeing if it fixes your issues, this is the primary one. Also in the service manual it tells you the resistance specs of the sender for testing. Good Luck!!! Fixing the FuelGauge.pdf Edited July 31, 2013 by SteveW 5 Quote
SteveW Posted December 28, 2011 Author Posted December 28, 2011 For further info Alex sells the tank O Rings, I've just ordered two off him, instead of tapping up Nissan, one for each side. So if you need them (I assume the other suppliers on here will also do them) They are £12.50 each. I'm getting towards the bottom of the tank now and the gauge still seems to be working Will keep this thread updated as the fuel gets used. Quote
trackpig Posted December 28, 2011 Posted December 28, 2011 Nice write up. It may come in handy one day Quote
SteveW Posted January 2, 2012 Author Posted January 2, 2012 Gauge is definitely fixed let it run right down and the gauge and fuel computer worked as expected down to 5 miles DTE at which point I brimmed it. Fuel gauge went right up to top above the full mark and computer predicted 390 miles remaining as it used to when I first got the car. Sweet! New O Rings also fitted and tank holds pressure again Quote
SteveW Posted January 2, 2012 Author Posted January 2, 2012 Mods please can this be made a sticky as the fuel gauge issue seems to be affecting a number of owners? Thanks Steve Quote
ZMANALEX Posted January 3, 2012 Posted January 3, 2012 Great write up Steve and a superb guide. Very well done mate. Alex. Quote
glrnet Posted January 3, 2012 Posted January 3, 2012 Brilliant Steve Mine is as bad as yours (54 plate) but I've got a Scangauge fitted which is pretty well spot on but it still annoys the cr*p out of me I've book marked this and I'll be giving this a go when the weather warms up a bit, thanks again Quote
Gudzy Posted January 10, 2012 Posted January 10, 2012 How long did this take roughly? I'm thinking of seeing if a garage would do it and I'd like an idea of how much they should be charging. Quote
SteveW Posted January 10, 2012 Author Posted January 10, 2012 Not long really I reckon about 45 mins per side as a maximum think it took me less than an hour. Quote
doctor austin Posted January 10, 2012 Posted January 10, 2012 Thank you Steve for a great write up... I hope I dont need to use it but if I do its going to be such a help. Brilliant Quote
MaDMaXX Posted March 17, 2012 Posted March 17, 2012 I really appreciate you making this guide, this problem has plagued the states cars for years it seems, there is a guide over here, but it's not quite as good as yours I think it's possibly the sulphur content in the fuel, it's really crap over here compared to the UK, either way, it's a sucky fault, manifests itself in various ways, but it's all the same thing. Ironically, mine is an '04 as well, really needs this doing, once it gets to a quarter tank, it drops like a stone, but then will recover and do the same thing over the course of the next few days driving until i really don't know how much is left in the tank Quote
SteveW Posted March 17, 2012 Author Posted March 17, 2012 No worries mate, hope you get it sorted. Mine was doing my head in never knowing how much juice was left. It's worked perfectly ever since. Quote
MaDMaXX Posted March 17, 2012 Posted March 17, 2012 Yeah, might be a project for next weekend perhaps, it's bugging me, but this weekend is Motordyne ART pipes and the XYZ pipe Quote
panrix Posted March 26, 2012 Posted March 26, 2012 Does this problem only affect certain aged cars or is it a general fault? Cheers Quote
MaDMaXX Posted March 28, 2012 Posted March 28, 2012 In the US, it seems to be a general fault, and as i said, there seems to be more cases of it here. Of course that could be down to a number of things, more Z's here, more vocal people here etc etc. Anyway, no one seems to know about the cause, just that it's dirt on the sensors, perhaps fuel related, perhaps even ethanol in the fuel related, which is way more prevalent in the states and has been for years. Quote
ed350Zee Posted April 2, 2012 Posted April 2, 2012 I think i will need to do this soon my gauge is a way off...the light came on the other day so i filled it up but only managed 50l of fuel?? These tanks hold 80l right? Can someone tell me the o-ring size required (cord ø x inside ø?) i might be able to get some from work...Cheers Quote
MaDMaXX Posted April 3, 2012 Posted April 3, 2012 Keep 'em dry and you can re-use the old ones, that's my plan, anyway. Quote
mikewagon Posted May 2, 2012 Posted May 2, 2012 can you use rubbing alcohol to clean the contacts or does it have to be a special contact cleaner? Quote
MaDMaXX Posted May 2, 2012 Posted May 2, 2012 Rubbing alchohol would work but contact cleaner is more effective, about 8 bucks from lowes. Quote
