alessandro Posted April 30, 2011 Share Posted April 30, 2011 Hppened 4 times in 2 days now  Only when approacing roundabouts or traffic ligths, if I down shift it's fine but, if I slow donwn with the car in gear and the clutch pressed the car smoothly switch off, no warning lights or any funny things, I reach the stop and the engine is off (only the inignition lights are on as when you turn the key without turning the engine on), happen earlyer on but I did noticed before reaching the stop, I gave it some gas and the engine re started with a bit of a "turbo lag" effect.  Doesn't happen all the time and when it does happen the car re starts with no proble, the only thing that I reacently changed is that I now fill up on normal petrol rather than 99.  Any ideas??  Thank Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted April 30, 2011 Share Posted April 30, 2011 My Alfa did this ..... isn't there an electrical anti stall mechanism that counts the flywheel revs somewhere ? Quote Link to comment Share on other sites More sharing options...
alessandro Posted April 30, 2011 Author Share Posted April 30, 2011 No idea, Ithought it could be down to the fuel pump or something  ( which Alfa did you have?) Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted April 30, 2011 Share Posted April 30, 2011 156 Quote Link to comment Share on other sites More sharing options...
Zugara Posted April 30, 2011 Share Posted April 30, 2011 Sure there was a post the other day about the same thing.... I have been using normal fuel for about 4 months with no problems, and the average mpg is the near enough the same when using 98 ron. Go figure.... Quote Link to comment Share on other sites More sharing options...
alessandro Posted April 30, 2011 Author Share Posted April 30, 2011 Sure there was a post the other day about the same thing....I have been using normal fuel for about 4 months with no problems, and the average mpg is the near enough the same when using 98 ron. Go figure.... Â Same here on mpg, I had to switch to get more juice in rather than increase mpg Quote Link to comment Share on other sites More sharing options...
Zugara Posted April 30, 2011 Share Posted April 30, 2011 viewtopic.php?f=9&t=33956&p=506166&hilit=engine+cuts+out#p506166 Â viewtopic.php?f=10&t=37150&p=554838&hilit=engine+cuts+out#p554838 Â May help Quote Link to comment Share on other sites More sharing options...
alessandro Posted April 30, 2011 Author Share Posted April 30, 2011 thanks mate  I dont think it's the samee issue but the first link it's probably the closer one to my problem except that mine doesnt shut while driving and doesnt stutter, however, I'll have a look at battery and filter in the morning Quote Link to comment Share on other sites More sharing options...
Dblock Posted April 30, 2011 Share Posted April 30, 2011 crank sensor? cam sensor? I thought JDM users had to stick to 99ron? Quote Link to comment Share on other sites More sharing options...
Demolition49 Posted May 2, 2011 Share Posted May 2, 2011 Hey mate sorry to hear about the Z having problems... I know the feeling! I reckon you should go back to 98 or better octane asap as the car is made to run on 98 running it with 95 can cause detonation when at full throttle as the engine only allows for detonation at part throttle! If you want to run off 95 get it mapped on 95? Quote Link to comment Share on other sites More sharing options...
doctor austin Posted May 2, 2011 Share Posted May 2, 2011 I run my jdm of regular petrol with no known issues ..28mpg on a reasonable run, smooth running etc..... bearing in mind I get through £100 of petrol per week the added expense of the higher octane fuel would add up...... so regular fuel shouldn't be an issue in my opinion Quote Link to comment Share on other sites More sharing options...
alessandro Posted May 2, 2011 Author Share Posted May 2, 2011 I had a go at thighting all the bits in the angine bay,like batteries filter etc.. everything seems ok and I had no issues yesterday  I might just pop into Japex for a pace of mind Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted May 3, 2011 Share Posted May 3, 2011 Sounds like a faulty Air flow meter to me. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 3, 2011 Share Posted May 3, 2011 Agree with Mark. Â viewtopic.php?f=157&t=43466 Â Alex. Quote Link to comment Share on other sites More sharing options...
Voodoo Vix Posted July 18, 2011 Share Posted July 18, 2011 Hi Alessandro  Did you solve this problem? Mine does it but very intermittently. First two times were on the way to JapShow in June she cut out twice going towards a roundabout off the motorway, where steering went so heavy I literally couldn't turn the wheel and had to bump start it. It also happened twice yesterday, once turning into a road, the other was coming off of the M25, yet again towards a tight turn. I need to solve this asap before my car kills me so any help is appreciated. Nissan said they've never heard of the problem before and said to do throttle resets etc. but wondered if you were able to cure your problem as it sounds similar to mine.  I did pm you but its still sitting in my outbox since last night.  Thanks  Vix Quote Link to comment Share on other sites More sharing options...
