rothers2901 Posted August 17, 2010 Posted August 17, 2010 Hi. I have the urge to squeeze a few more HP out of my Z (04 plate). The problem that i have is that i have read somewhere, that by installing a Plenum spacer and a pannel filter you can gain a few more HP. On the other hand i have also read that because the Z has a specific type of ECU and air folw meter they would recognise the changes and adjust things accordingly which would result in no gains at all. I would appreciate any advise at all, and if any one could back up the claims with power print outs even better. Thanks Rothers2901 Quote
introspect Posted August 17, 2010 Posted August 17, 2010 Plenum spacer and a decent panel filter are good modifications, but you'll really need to get an Uprev tune to get the best out of them. Tuning the ECU is the best way to improve performance. Quote
Husky Posted August 17, 2010 Posted August 17, 2010 agreed, plenum spacer has proven gains due to the front two cylinders being starved with the design of the plenum (due to the strut bar being in the way). panel filter with post 06 air box is the best for power gains. A tune once you have done your mods then makes the most of the money you have spent. i'd probably stop about there tbh otherwise you're burning money. you may get to about the 300bhp mark from that. (maybe) this is all assuming you are in a pre 06 car. Quote
dyla350z Posted August 17, 2010 Posted August 17, 2010 Had the uprev,plen&drop in filter from abbey,9bhp gain,you do notice it&im pleased with results,i may be wrong but i dont think your get 300bhp unless you change the cats/decat&new system,still think you may bay 5 or 6bhp short Quote
introspect Posted August 17, 2010 Posted August 17, 2010 Just remember you're never going to get big top end gains from a NA engine. It's not all about the top end numbers though, it's more about improving the feel of the car and smoothing out the power low down which greatly improves drivability. Quote
rothers2901 Posted August 17, 2010 Author Posted August 17, 2010 Thanks all for the advise. But what is a uprev tune. Thanks Rothers Quote
captain Posted August 17, 2010 Posted August 17, 2010 Thanks all for the advise. But what is a uprev tune. Thanks Rothers http://www.abbeymotorsport.co.uk/site_flash/index3.html Quote
spursmaddave Posted August 17, 2010 Posted August 17, 2010 Even more info for the lazy.... http://lmgtfy.com/?q=350z+uprev Quote
introspect Posted August 17, 2010 Posted August 17, 2010 Uprev is basically software for tuning the standard ECU. Abbey Motorsport and RS Tuning and (I think) Advanced Motorsport all offer this. Have a look here http://www.350z-uk.com/forum/viewforum.php?f=114 and here http://www.350z-uk.com/forum/viewforum.php?f=131 for some more info Quote
MrLizard Posted August 17, 2010 Posted August 17, 2010 I use the UpRev tune which was done by Abbey on the race car, all I can say is it is well worth the money! the car drives so much better, Mark worked his magic and squeezed another 40bhp out of mine which was running below where it should have been as well as sorting the throttle control out you wont be dissapointed, your probably better off talking to Mark or Scott @ Abbey on the subject Quote
ben p Posted August 17, 2010 Posted August 17, 2010 Even more info for the lazy.... http://lmgtfy.com/?q=350z+uprev Ha, that's brilliant! not seen that before. Quote
showtime1 Posted August 23, 2010 Posted August 23, 2010 i recently fitted a plenium i have 06 airbox with k&n filter managed 295 at rs tuning in leeds from 270 a few months back standard. Had the uprev,plen&drop in filter from abbey,9bhp gain,you do notice it&im pleased with results,i may be wrong but i dont think your get 300bhp unless you change the cats/decat&new system,still think you may bay 5 or 6bhp short Quote
M13KYF Posted August 23, 2010 Posted August 23, 2010 also RS Tuning do a uprev and based more locally to you in Leeds Quote
rtbiscuit Posted August 23, 2010 Posted August 23, 2010 pre 06 wont hit 300bhp with an exhaust and de cat pipes. would you notice the difference without them... apart from the noise... not really uprev will give your car a breath of life; not so much in the power, but the response and feel of the car. abbey is well worth the trip Quote
