linkster Posted February 24, 2010 Posted February 24, 2010 I've read through the American forums and sent links on all I could find to my local garage, who had the 54 plate 40k miles in all of yesterday trying to track down this noise that's just started - basically a thump or rattle, even on straight road, but not constant. had four new tyres recently and the front brake pads replaced. They cannot find any worn parts but he thinks it's the suspension on the way out and wants to start replacing cheapest parts first, starting with the drop links. Just thought I'd post and see if there was any advice Quote
M13KYF Posted February 24, 2010 Posted February 24, 2010 engine mounts exhaust knocking droplinks knackered or dry track rod ends worn suspension bushes Quote
cookiemonster Posted February 24, 2010 Posted February 24, 2010 Think Mike has sumed it up nicely. The end links are the problem on mine and it makes a similar knocking noise. Quote
linkster Posted February 24, 2010 Author Posted February 24, 2010 engine mountsexhaust knocking droplinks knackered or dry track rod ends worn suspension bushes thanks! 3 of the 5 they've already mentioned to me as suspects, but obviously we don't know for sure without replacing them, so as mentioned he's starting with the cheapest one first. Here's hoping it doesn't get too expensive!! Quote
mic-39 Posted February 24, 2010 Posted February 24, 2010 viewtopic.php?f=3&t=30773&start=30&hilit=suspension+knocking viewtopic.php?f=9&t=25519&start=0&hilit=suspension+knocking viewtopic.php?f=9&t=19045&start=15&hilit=suspension+knocking Quote
stanski Posted February 24, 2010 Posted February 24, 2010 Sure you havnt got someone hiding in the boot ! Quote
linkster Posted February 24, 2010 Author Posted February 24, 2010 http://www.350z-uk.com/forum/viewtopic.php?f=3&t=30773&start=30&hilit=suspension+knocking viewtopic.php?f=9&t=25519&start=0&hilit=suspension+knocking viewtopic.php?f=9&t=19045&start=15&hilit=suspension+knocking That sounds almost identical. Thank you. £300 :facepalm: Quote
scottsoulby Posted February 24, 2010 Posted February 24, 2010 If you need any parts pm zmanalex, he'll sort you out, I had a knocking sound that turned out to be the lower arm (banana bar) the ball joint was gone Quote
linkster Posted April 13, 2010 Author Posted April 13, 2010 Ok, am £80 poorer and no further on. If I was in any position to drive to Alex who has been incredibly helpful I would, but my local garage unfortunately doesn't seem very interested in following the advice given. I tried calling Antelope Nissan in Banbury who couldn't have been less helpful, telling me they'd charge to even diagnose the problem. In short then, can anyone advise a reputable garage in the Midlands (I'm near Daventry) to whom I could pass the info I have and act on it in a helpful way? Quote
M13KYF Posted April 13, 2010 Posted April 13, 2010 what about Abbey, not midlands but nearer than Alex Quote
linkster Posted April 13, 2010 Author Posted April 13, 2010 k, I gave them a call, waiting on Mark calling me back. fingers crossed. Quote
350ash Posted April 13, 2010 Posted April 13, 2010 I think CS are based in the Midlands and I've read good things about them on this forum. I'm sure someone will be along soon to confirm this... Quote
M13KYF Posted April 13, 2010 Posted April 13, 2010 CS is in Leicester, Defo another one worth trying Quote
ATTAK Z Posted April 13, 2010 Posted April 13, 2010 "Gentle knocking from front suspension when going v slowly down rutted tracks (fine on the roads) - (ABR links? Lower balljoints?)" I had this - worst when going slowly over raised road markings like the chevrons outside a school changed drop links LHS & RHS changed lower suspension arms LHS & RHS changed upper wishbone LHS only No change except getting louder - still only at low speed over very small bumps At this point I started thinking about selling changed tie bar LHS (really a strut as it's always in compression)( nicknamed 'banana bar' on here) Eureka front suspension.pdf My money's on the banana bar (number 11 in the *.pdf) Quote
clarkie34 Posted April 13, 2010 Posted April 13, 2010 Mine goes in on Monday for the Banana bar,ball joint has collapsed on it.The noise is like a creaking noise when turning the wheel when stationary,sounds like an old cart. Quote
linkster Posted April 13, 2010 Author Posted April 13, 2010 CS sounds promising, anyone have contact details? Quote
Wookiee22 Posted April 13, 2010 Posted April 13, 2010 CS sounds promising, anyone have contact details? Shoot him a PM on here. Normally very quick to respond. Quote
nixy Posted April 13, 2010 Posted April 13, 2010 mine was doing similar. started suddenly and at first i thought something was knocking about in the boot! Then it started creaking as well. It was the drop links. Quote
