Posted (edited)
Had steering wheel and cabin judder under braking for a couple of months.
I have changed the discs twice and the issue goes completely away for a week or so and then gradually comes back.
I have:
  • Replaced discs and pads (short term fix then comes back as above).
  • Had the bearings/hubs tested for runout.
  • Replaced a wheel bearing which showed some runout (no effect).
  • Replaced both lower control arms/wishbones (no effect).
Other things to note:
  • All discs and pads have been Pagid. Maybe a bad production run/batch?
  • Vibrates less the harder you press, but you have to press really hard to not feel it.
  • It's mainly the steering wheel and cabin that vibrates, not the brake pedal.
  • There is a slight squeak on right lock you can hear when parking.
  • Car pulls to the left a little more than it has recently.
Any ideas/help would be much appreciated as not wanting to throw endless amounts at the car as it is now on 100k miles. Would be a shame to let it go but thinking about cutting losses.
Edited by Blackstar
