Hi all,
I’m planning to make an offer for a 350z, 53 Reg, around 148,000 miles.
This will be my first sports car if you would like. I haven’t inspected it at all and I plan to do so with a mate who works as a mechanic so has more insights.
1. What do I look out for during my inspection?
2. How can I tell if this car was look after?
3. If we identify issues or works to be done, What would be a reasonable offer without offending the owner?
4. Are they worth and do they hold its value?
Thanks,
S
1. What do I look out for during my inspection? - Rust around wheel arches, oil leaks & rad fan are the main ones that I can think of
2. How can I tell if this car was look after? Good service history and MOT history.
3. If we identify issues or works to be done, What would be a reasonable offer without offending the owner? Depends on what needs doing really, biggest issue will be rust, can cost £1000++ to sort out properly
4. Are they worth and do they hold its value? Zed has gone up in value recently due to boom in 2nd hand car market and I suspect it will go down once the issue is sorted (electronics components shortage leading to long lead time for brand new car). For this, i think zed's value are based on market rather than being a rare car/soon to be classic.
Good luck in your hunt.
Posted (edited)
18 hours ago, SNEW350 said:
Hi all,
Thanks,
S
I made quite an extensive inspection checklist when I was looking for 350Z's. Interested? It's an Excel sheet.
EDIT: Maybe share a link or some photos of the car? PM me directly if you don't want to share publicly.
Edited by polaris
Posted (edited)
34 minutes ago, SNEW350 said:
That's pretty bad - I'd be concerned about how the car looks underneath. Depending on your budget I'd look elsewhere; there are nicer examples to be had. Regardless, 2003, 150k miles and doesn't start: £1-2k?
Edited by polaris
Thank you for your response.
It didn’t started because the battery was flat. No other reason at this stage.
Yes I do agree - there maybe further rust underneath. It was dark and I don’t like viewing cars in the evening but it was the only time my expert mate was around.
My budget was around 2.5k max. Reasonable?
Hi and welcome from Bristol, i personally think that you have your work cut out with finding a good zed within your budget.
Sorry for being blunt, i think 6k plus for anything descent.
Good luck with your search
Thanks mate.
I meant I don’t mind paying 2.5k max for this one and I can then perhaps use the rest to sort out rust etc.
But I do agree - 6k as the right budget to find a good one and I’ll focus on that.
Posted (edited)
2 hours ago, SNEW350 said:
Thanks mate.
I'd walk away if your budget was 2.5k. The cheapest 350Z coupe on AutoTrader right now is 4k and it looks in much better nick, albeit a few rust spots. Like Paul said, if you can spend the money and get a nice example then that's the best route. Save yourself the hassle. You'll probably spend 2k repairing it anyway...
Edited by polaris
Yes I think that’s the sensible thing to do here. Thank you so much for your advice. I’ll revisit the hunt in the near future.
11 hours ago, Mikey_S said:
In terms of your budget, have you budgeted ongoing maintenance? These cars aren't cheap to run and maintain whatever state they are in.
Hi mate - yes I have and my best is a master technician so labour wouldn’t be an issue.
what would you say are the major ongoing maintenance costs to lookout for?
Thank you.
That's a lil bonus for you then :thumbs:. I would say fuel obviously, these things work best on the premium unleaded.
Regular oil changes, servicing and tyres I would say are the main ones then anything that goes wrong like the clutch which then makes sense to change the flywheel and slave while it's out 🤣. The list goes on but hopefully you get one you like
Thank you for your response. It is appreciated 😀
  • 1 month later...
