EvansJD2112 Posted April 10, 2019 Posted April 10, 2019 (edited) Now with front 25mm spacers. Great service from Tarmac Sportz :-) Much better. Tarmac sportz spacers bought of a member. Not sure if I need front now or not....... Edited April 13, 2019 by EvansJD2112 Quote
EvansJD2112 Posted April 10, 2019 Author Posted April 10, 2019 39 minutes ago, buster said: 20mm front would help imo. Donations happily accepted :-) 2 Quote
Payco Posted April 10, 2019 Posted April 10, 2019 You do mate. It doesn't look right spaced 25mm rear and stock front. Quote
Andy_Muxlow Posted April 10, 2019 Posted April 10, 2019 I would go 25 at the front as well myself as that's what i did. Looks much better spaced. Quote
EvansJD2112 Posted April 10, 2019 Author Posted April 10, 2019 Just now, Andy_Muxlow said: I would go 25 at the front as well myself as that's what i did. Looks much better spaced. Stock springs and wheels? Quote
Andy_Muxlow Posted April 10, 2019 Posted April 10, 2019 Just now, EvansJD2112 said: Stock springs and wheels? Stock rays wheels yes, but on Eibach lowering springs. 1 Quote
GranTurismoEra Posted April 10, 2019 Posted April 10, 2019 isnt it 20mm + 3 mm shims at the front? Quote
Silverthorn Posted April 10, 2019 Posted April 10, 2019 (edited) Due to the length of the studs you'll have to either go 20mm spacer + a 3mm shim or just a 25mm spacer. For the sake of being easy I'd just go with the 25mm I purchased 20mm without realising the stud length was 23mm and had to get a set of 3mm shim spacers to allow me to fit them. Rear looks spot on with the spacers fitted though. The wheels look so lost in those huge arches from standard! Edited April 10, 2019 by Silverthorn Quote
EvansJD2112 Posted April 10, 2019 Author Posted April 10, 2019 1 hour ago, Silverthorn said: Due to the length of the studs you'll have to either go 20mm spacer + a 3mm shim or just a 25mm spacer. For the sake of being easy I'd just go with the 25mm I purchased 20mm without realising the stud length was 23mm and had to get a set of 3mm shim spacers to allow me to fit them. Rear looks spot on with the spacers fitted though. The wheels look so lost in those huge arches from standard! Good info, thanks Quote
buster Posted April 10, 2019 Posted April 10, 2019 25mm if you have aftermarket wheel,o/e can do 20mm due to slots in rear face on said wheel.most after market don t . Quote
EvansJD2112 Posted April 10, 2019 Author Posted April 10, 2019 That ring true for the 2018 model I have with the black diamond cut alloys? Quote
sipar69 Posted April 11, 2019 Posted April 11, 2019 Assuming you're genuinely interested in what people think, I think it looks pretty weird with a hefty spacer at the back and nothing at the front. Definitely needs at least 20mm at the front to balance it out. Quote
EvansJD2112 Posted April 11, 2019 Author Posted April 11, 2019 25mm ordered for the front :-) 2 Quote
