Guest prescience Posted January 2, 2006 Posted January 2, 2006 The following pinouts on the stock ECU apply: http://www.cj-motorsports.com/products/350ztech1.htm Quote
StephenG Posted January 20, 2006 Posted January 20, 2006 The following pinouts on the stock ECU apply: http://www.cj-motorsports.com/products/350ztech1.htm UK cars as well? Quote
Guest prescience Posted January 20, 2006 Posted January 20, 2006 I will PM phunk (Charles) on my350z and ask him Quote
Removed Posted January 20, 2006 Posted January 20, 2006 the UK service manual will come in handy too... i think they refer to ECU as ECM Quote
Guest prescience Posted January 25, 2006 Posted January 25, 2006 I have just received the following confirmation from Charles (phunk) on my 350z. The file you sent me is definitely correct for the Z you are concerned about, all major components and circuits were on the same pins as the pinout on my website. I will be cross-referencing the pinout with a USDM 2004 and if its still all the same then I will update the page to confirm its accurate for 03-04 , and I have the 05 manuals now so I can go thru those So we can use that information above as posted Quote
Removed Posted January 25, 2006 Posted January 25, 2006 oooooo sounds good then.... UTEC hasn't answered me yet btw Quote
StephenG Posted January 25, 2006 Posted January 25, 2006 oooooo sounds good then.... UTEC hasn't answered me yet btw I am in correspondence with them directly - I'll let you know on here when I get a reply. Quote
Removed Posted January 25, 2006 Posted January 25, 2006 oooooo sounds good then.... UTEC hasn't answered me yet btw I am in correspondence with them directly - I'll let you know on here when I get a reply. well I am too, once they answer me PS would have helped if you mentioned it, saving me writing the email.... Quote
TurboXSJermaine Posted January 25, 2006 Posted January 25, 2006 Hi Guys, I finally made it over here. It looks like I thought it would. Most of the critical wires are located in the right place. Nissan, has made this fairly easy for us to implement the UTEC on multiple platforms. Thanks, Jermaine@turboxs.com Quote
Guest prescience Posted January 25, 2006 Posted January 25, 2006 Great result Jermaine. Do you have pre-tuned maps for Vortech S/C? Any plans to get tuners here in the UK up to speed with the unit? Quote
Removed Posted January 26, 2006 Posted January 26, 2006 welcome on board Jermaine!!! have a read of my last email... Dorian, you have PM Quote
carworx_will Posted June 11, 2006 Posted June 11, 2006 The link isnt working for me?? Anyone got a copy the could email to me? Quote
BB Jon Posted June 26, 2006 Posted June 26, 2006 The link isnt working for me?? Anyone got a copy the could email to me? The link has changed to http://www.cj-motorsports.com/350ztech1.htm Cheers[/url] Quote
Ekona Posted February 19, 2008 Posted February 19, 2008 Just in case anyone else wants to know, the link has now changed to http://www.cj-motorsports.com/03pinout.htm Dan Quote
Karl H-Williams Posted November 15, 2009 Posted November 15, 2009 Just a quick note of thanks to this forum and the contributors who set me right. My 05 350Z has performed pretty much like a dream with only a few minor hickups fromk new; however most recently last Friday 13th, I came home as usual from work, parked up on the drive, but Saturday morning I suffered a non starting car... Turned over, a dream, and petrol pump primed a ok, bit no ignition. Cranked over strong but no spark... definitely fuel in the system and getting into the pots etc as I could smell the un burnt petrol at the tail pipes.... Spent Saturday and all day today scratching my head and wondering how I could get my car to my dealership, who I have to commend as being excellent... not sure if I can advertise here, but suffice to say they have never failed me. So being an old school mechanic (hobbyist) I knew I was not in a position to tinker... so found this site and second message I read completely described my plight. I selected my alternate key just in case the main had a tired battery which I think may have been contributory, and the Z fired up after a couple of attempts, a bit lumpy, but better than the last efforts over the weekend... then with the tell tale dash lights illuminated I followed the ECU reset process ... and all came good. I hope I can help others in the same way I was helped today... thank you to "Z Veteran" whose content directly resulted in a win... Much appreciated sir. Quote
350SX Posted June 28, 2012 Posted June 28, 2012 Does anybody have a working link to the ECU pinout please? None of the above pages are there anymore. I'm after a diagram for a 52 plate JDM model if it makes a difference. Thanks Quote
Lexx Posted June 28, 2012 Posted June 28, 2012 http://www.innovatemotorsports.com/reso ... 5_350z.php Quote
richie19942 Posted April 1, 2018 Posted April 1, 2018 Any updated pinout diagrams? None of the above links work and google isn't being a friend for once Quote
350Butcher Posted April 2, 2018 Posted April 2, 2018 Not sure if this is what you're after but........ go here http://www.nicoclub.com/FSM/350Z/ Select your model of Z and select EC.pdf and in the index look for "ECM Harness Connector Terminal Layout" (DE page Pg94-95 and HR Pg103) This will give you a full list of all 120+ pins location and function Ps download the lot for your car.........such a useful thing to have Quote
richie19942 Posted April 2, 2018 Posted April 2, 2018 8 hours ago, 350Butcher said: Not sure if this is what you're after but........ go here http://www.nicoclub.com/FSM/350Z/ Select your model of Z and select EC.pdf and in the index look for "ECM Harness Connector Terminal Layout" (DE page Pg94-95 and HR Pg103) This will give you a full list of all 120+ pins location and function Ps download the lot for your car.........such a useful thing to have Perfect! I was looking at this last night but was looking at BCS instead of EC. Thanks for the guidance, i've now downloaded the whole service manual. Quote
Mark@Abbey m/s Posted November 2, 2019 Posted November 2, 2019 On 02/04/2018 at 08:28, 350Butcher said: Not sure if this is what you're after but........ go here http://www.nicoclub.com/FSM/350Z/ Select your model of Z and select EC.pdf and in the index look for "ECM Harness Connector Terminal Layout" (DE page Pg94-95 and HR Pg103) This will give you a full list of all 120+ pins location and function Ps download the lot for your car.........such a useful thing to have One thing thou these are US car's. The DE car specs between UK-US and JDM are all a little different Mainly O2 sensors All The UK DE (276bhp) have wide-band lambda's Early US and Early JDM cars have a different wide band sensor think is was 2005 be fore the JDM/US cars went fully wideband But there are differences in the wiring between the cars dependant where they where built fo. Quote
