mr_smith126 Posted August 18, 2016 Posted August 18, 2016 Cleaning the car the other day i noticed a load of black gunk splattered over one side of the exhaust.. So my stock silicone filled rear bush on the diff has split. Two questions.. What do people recommend from experience, a few people offer these kits, whiteline etc.. And probably more importantly as I have no tools.. Japex will probably be replacing for me, can this be done without removing subframe etc.. Thanks. Quote
StevoD Posted August 18, 2016 Posted August 18, 2016 (edited) Im guessing japex is the one to answer if it can be done from not removing the subframe but the sub frame is aluminum so putting pressure the wrong way trying to remove or install the bush could twist it although Z1 do a tool so you dont have to remove the subframe which i have bought for changing the diff bushes when i get the time Edited August 18, 2016 by StevoD Quote
davey_83 Posted August 18, 2016 Posted August 18, 2016 Ive recently had mine replace by Cougar Store, the diff is drop'd however the ally subframe remains in place. I had the whiteline kit fitted, however wouldn't have a problem with using SuperPro. Ish 3.5hr-4hr labour for the work then of course the price of the kit on top. Quote
evilscorp Posted August 18, 2016 Posted August 18, 2016 I did nick my subframe with the sawzall even when I had the subframe out, ended up having a specialist put a small weld to fill the nick as it would play on my mind, this guy doesn't seem to care tho Quote
nissanman312 Posted August 19, 2016 Posted August 19, 2016 Did mine the other week I didn't remove the subframe And used Whiteline diff bushing kit 1 Quote
F100Jay Posted September 29, 2016 Posted September 29, 2016 Does gearshift feel improve as they claim? Or have you noticed any improvements at all in the way the car feels or drives? Quote
evest Posted September 30, 2016 Posted September 30, 2016 I fitted Whiteline mate - did not touch the subframe. I did round off the nut inside the bushing though, before dropping the diff! That was interesting... Quote
roadtrip Posted September 30, 2016 Posted September 30, 2016 I had mine replaced by Abbey Motorsport using the Whiteline kit and I'm pretty sure they didn't remove the subframe. I've not noticed any gearshift or other improvements since though. Quote
nissanman312 Posted September 30, 2016 Posted September 30, 2016 I definitely didn't remove my subframe Quote
mr_smith126 Posted September 30, 2016 Author Posted September 30, 2016 So had the whiteline kit fitted, diff dropped to replace. I haven't noticed any difference what so ever... just something that was broken is now fixed Quote
cascade88 Posted October 1, 2016 Posted October 1, 2016 Did mine myself also on jack stands. Dropped subframe ever so slightly my loosening all mounting bolts to give better access for getting old bush out / new in. Quote
