spunkehmunkey Posted October 14, 2015 Posted October 14, 2015 Thought I would start a pretty simple topic. What RPM do you guys normally sit at when cruising? DO you put it in the highest gear possible or do you like to sit at a higher rpm of 3k? Would love to know, might find a sweet spot of available power and good mpg Quote
FiddyZed Posted October 14, 2015 Posted October 14, 2015 Whilst cruising I try to stick to about 2,500 rpm. Sometimes I'll try and put it in a highish gear but prefer to have it at where I think is a good balance of economy and power (If this even exists with a zed). Quote
-Bradders- Posted October 14, 2015 Posted October 14, 2015 (edited) i stick 68mph (cruise control) which is bang on 2500rpm, i found that best for 34-36mpg on a long run Edited October 14, 2015 by -Bradders- Quote
spunkehmunkey Posted October 14, 2015 Author Posted October 14, 2015 I tend to stick at about 2500rpm myself aswell. Sometimes I let it climb to around 3k (I do not have a custom exhaust yet so noise isn't an issue). I feel like anything below 2000 would be making the engine work too hard! Quote
tommoger Posted October 14, 2015 Posted October 14, 2015 (edited) 2500rpm gives me 73mph in 6th so sit just below that of course Sent from my iPhone using Tapatalk Edited October 14, 2015 by tommoger Quote
brillomaster Posted October 14, 2015 Posted October 14, 2015 when literally cruising, probably about 1500rpm, so would normally change up as soon as possible really. Unless I require any kind of acceleration, in which case i'd drop a gear pretty sharpish. i'm pretty sure that if you're stuck in a line of traffic doing 40mph with no prospects of overtaking, the best fuel economy is to put it in 6th. motorway cruising doesn't really count as nobody in their right mind would cruise along a motorway in anything other than 6th gear, just cost that's the highest gear. but ideally i'd be cruising at a lower rpm for better economy. All that said, pick up is pretty poor below 3,000rpm, being an NA engine it does need some revs to make power. Quote
Quinster Posted October 14, 2015 Posted October 14, 2015 Mines is an Automatic. I just let mines do the work. Quote
jimmy.farrow7 Posted October 14, 2015 Posted October 14, 2015 I more often than not stick around 2500RPM Quote
HiddenWomble Posted October 14, 2015 Posted October 14, 2015 Motorway is 6th gear, but at slower speeds I like to stay close to 2K when cruising. Plenty of grunt to change speed in traffic, and always the option to drop a gear if I want her to pull hard. Quote
-Bradders- Posted October 15, 2015 Posted October 15, 2015 2500rpm gives me 73mph in 6th so sit just below that of course Sent from my iPhone using Tapatalk HR? Quote
Grundy Posted October 15, 2015 Posted October 15, 2015 You guys do know, higher gear doesn't mean better MPG... Granted don't be cruising at 70 in 3rd, but doing 40 in 6th is doing you no favours either. 1 Quote
tommoger Posted October 15, 2015 Posted October 15, 2015 (edited) 2500rpm gives me 73mph in 6th so sit just below that of course Sent from my iPhone using Tapatalk HR? DE Sent from my iPhone using Tapatalk Edited October 15, 2015 by tommoger Quote
-Bradders- Posted October 15, 2015 Posted October 15, 2015 :O how? lol i got de its 68mph at 2500 lol Quote
Kaveney Posted October 15, 2015 Posted October 15, 2015 most of the time im at 1000 or 900 RPM in 6th is this not the best for fuel saving then ? I thought the lower the RPM the better ? Alan You guys do know, higher gear doesn't mean better MPG... Granted don't be cruising at 70 in 3rd, but doing 40 in 6th is doing you no favours either. Quote
brillomaster Posted October 15, 2015 Posted October 15, 2015 doing 40mph in 6th is fine for simply cruising... you probably need about 20 bhp to cruise along at 40mph, which 6th gear can comfortably provide. Obviously don't expect much acceleration from 1300rpm, but the engine is perfectly happy with doing sustained running at that speed. theres a reason why autoboxes shuffle up gears as quickly as possible - my beemer driven gently in full auto mode never goes above 1500rpm. Quote
H1979 Posted October 15, 2015 Posted October 15, 2015 You guys do know, higher gear doesn't mean better MPG... Granted don't be cruising at 70 in 3rd, but doing 40 in 6th is doing you no favours either. Genuine question, why is it doing you no favours, apart from the obvious that you won't be able to out accelerate anything. Quote
spunkehmunkey Posted October 15, 2015 Author Posted October 15, 2015 My personal thoughts were that a low rpm meant the engine had to work a lot harder but at the same time the idle sits at 700-800rpm so surely the engine is comfortable in this band. Of course I know nothing about how engines work and that is at least partly why I posed this question Quote
Tom-89 Posted October 15, 2015 Posted October 15, 2015 at idle there is no load on the engine though. it's all about being in the right gear rather than the highest gear possible. I always think if you put your foot down and it doesn't pick up cleanly you're in too high a gear Quote
Sargara Posted October 16, 2015 Posted October 16, 2015 My car probably spends 90% of its life between 2000 - 3000 at which point I would normally change down or up. I mainly commute through average speed camera zones In Nottingham so I often use cruise control Quote
roscopervis Posted October 16, 2015 Posted October 16, 2015 Think of yourself on a pushbike - one with gears. You wouldn't ride around on the hardest to pedal gear when going slow, it's hard work. Similarly, you wouldn't be in the really easy gear when going fast, It's the same for the engine, it uses more energy thus fuel when accelerating from low revs in a high gear than it would in a comforable to spin gear. When cruising along, this is slightly changed, provided you don't need any kind of acceleration,6th is ok. The amount of throttle dictates how much fuel you use, the time you're using it therefore has an impact - accelerate briskly, without using too much throttle for best mpg. Quote
monkeybrain1234 Posted October 18, 2015 Posted October 18, 2015 3000 - 4000 rpm for normal driving. I can't imagine bumbling along at 1500 rpm. For me it defeats the object of owning a car like this. Quote
Rock_Steady Posted October 19, 2015 Posted October 19, 2015 3000 - 4000 rpm for normal driving. I can't imagine bumbling along at 1500 rpm. For me it defeats the object of owning a car like this. Really??? I quite like it. You can burble along in 4th doing 30mph and put your foot down for 3.5 litres of torque to waft you along. Use the torque young Jedi!! Quote
