<NEWBIE> Loud Idle
S7nny
Hey everyone. This is going to be pretty vague, so I apologise in advance. When the engine is cold and I start my Z up it sounds like the idle is quite loud. I'm not sure if this is a standard 350 trait, or if it is slightly abnormal. I've tried videoing it but the sound quality isn't good enough and doesn't really highlight what I'm hearing.
I did have a search for similar issues but couldn't find anything.
Any help/advice would be appreciated.
My bad; should've specified what I had! Mine is a 2006 GT DE. Depressing the clutch does reduce the whirring sound, but still leaves quite a loud idle.
I'll check the Rev count when I'm next in it and see where it idles on cold and then I'll see how it is when it's warmed up and report back!
Compete spaz when it comes to these things so thanks for being patient!
I have a 2004 GT DE and yes initial cold idle is rather loud. As for idle speeds, measured these about a year ago. Look at RPM/Min (4th line down)
Cold
http://vid142.photobucket.com/albums/r103/computerstar2000/226D4072-F1D8-48E8-A929-14EBDBEB00EA-4624-000002D30183FE92.mp4
Warm
http://vid142.photobucket.com/albums/r103/computerstar2000/0A4F61B6-335E-49C9-A708-154930D524EC-4624-000002D3135E007E.mp4
Just a thought mine idles (or did idle) at 1100rpm because I got it set like that because I felt it idled better at that speed.
Maybe the previous owner had the same done?
Edit. Yours idles at 650rpm. Ok.
I think maybe you're just over thinking it :)
Edited by TT350
