P15UL T Posted November 3, 2007 Posted November 3, 2007 Just had a new set of Kinetix hight flow cats fitted and i have noticed thew Engine Malfunction light is on ( the one like a little box with 2 T shapes coming off it ) is this anything to worry about or will the ecu sort itself out soon enough ? also when the mechanic was fitting them he said the originals had a sort of brace that bolted between then and that the kinetix didnt have mounting points for it to go back on, has anyone else cames across this and found a solution to the bar or is it even needed ? cheers again guy for all your help and knowledge oh and by the way... they sound A-MAZING !!!! Paul Quote
satsuma71 Posted November 3, 2007 Posted November 3, 2007 Just had a new set of Kinetix hight flow cats fitted and i have noticed thew Engine Malfunction light is on ( the one like a little box with 2 T shapes coming off it ) is this anything to worry about or will the ecu sort itself out soon enough ? also when the mechanic was fitting them he said the originals had a sort of brace that bolted between then and that the kinetix didnt have mounting points for it to go back on, has anyone else cames across this and found a solution to the bar or is it even needed ? cheers again guy for all your help and knowledge oh and by the way... they sound A-MAZING !!!! Paul Paul First, fitting hiflows should NOT put the CEL light on, not unless a lambda probe has been damaged removing it, or one has just decided it's had enough, they are really tight to get out of the cats, and can be damaged if not extremely carefull when removing. Secondly, the Kinetix cats are a lot lighter than the Nissan ones, and as such do not require the brace bar, just keep it in case you sell them in the future, and wish to revert to the originals. And yes they do sound awesome, especially with an aftermarket zorst enjoy Paul. ps, try an ECU reset Ian SATS Quote
Mitchell Posted November 4, 2007 Posted November 4, 2007 Hi, just de-catted mine and after a day the engine management light came on. If i do the ECU reset procedure will it go off and stay off or just come back on again? Is there any cheat / ecu upgrade etc to get the light to stay off? Also took the mounting brace off, doesnt seem to cause any probs with it off! Quote
Ian Posted November 4, 2007 Posted November 4, 2007 Hi, just de-catted mine and after a day the engine management light came on.If i do the ECU reset procedure will it go off and stay off or just come back on again? Is there any cheat / ecu upgrade etc to get the light to stay off? Also took the mounting brace off, doesnt seem to cause any probs with it off! It will come back on after around 50miles. You can buy non foulers for them from Envy or a trader on my350z.com - these are not guaranteed to clear the light though, even with them in I still got the CEL but it went away after i did an ECU reset with my Digimoto software. The brace is not needed - mine is in the garage with my standard cats Quote
Mitchell Posted November 5, 2007 Posted November 5, 2007 Can't seem to find them on the Envy website. Anyone have a link? Quote
Mitchell Posted November 7, 2007 Posted November 7, 2007 Does the ECU light on mean that the engine is running in a safe mode or something or will it still be giving its full power etc. Any damage likely to result from running with it on? Quote
Zedrush Posted November 7, 2007 Posted November 7, 2007 Mine comes on and off, had a diognosis test and the readings of my cats were fine, friend took the light off then after a while came back on again, he said its nothing to worry about, said could try playing with the sensors, it just means the sensors recognise a different flow to what its usually use to and is program to show up as a warning I think. If a lambder probe is broken are these easy cheap to replace? Been told if I drive the car hard all the time the light wouldnt come on Quote
sl114 Posted November 7, 2007 Posted November 7, 2007 This seems to be coming up quite a lot now from people who have fitted high-flow cats and i am still sticking to my intitial thoughts as it does effect emissions and the 1st and 2nd sensor are not showing the correct readings, hence the engine light comes on as it thinks there is a fault. You need something to bypass the 2nd sensor and trick it to thinking its getting the right reading. Quote
Zedrush Posted November 7, 2007 Posted November 7, 2007 This seems to be coming up quite a lot now from people who have fitted high-flow cats and i am still sticking to my intitial thoughts as it does effect emissions and the 1st and 2nd sensor are not showing the correct readings, hence the engine light comes on as it thinks there is a fault. You need something to bypass the 2nd sensor and trick it to thinking its getting the right reading. Thats what my mechanic said as the readings on the 2nd sensor was not showing correct reading. Quote
Pingu2 Posted November 7, 2007 Posted November 7, 2007 hmm ive never had the light come on with my kinetix cats which ive had for about 5k miles now.. dont think the mechanic did anything special when installing them either.. odd Quote
Guest prescience Posted November 7, 2007 Posted November 7, 2007 This seems to be coming up quite a lot now from people who have fitted high-flow cats and i am still sticking to my intitial thoughts as it does effect emissions and the 1st and 2nd sensor are not showing the correct readings, hence the engine light comes on as it thinks there is a fault. You need something to bypass the 2nd sensor and trick it to thinking its getting the right reading. I agree, I think it will happen less often with hi-flos than with decats but it will still happen IMO when the second sensor detects an unusual flow. The first sensor is not related since this is BEFORE the cat - its purpose is to provide fuel mixture feedback to the ECU (many times a second) so that fuel trims can be adjusted to keep the correct AFR ratio (nominally 14.7:1) Quote
sl114 Posted November 7, 2007 Posted November 7, 2007 This seems to be coming up quite a lot now from people who have fitted high-flow cats and i am still sticking to my intitial thoughts as it does effect emissions and the 1st and 2nd sensor are not showing the correct readings, hence the engine light comes on as it thinks there is a fault. You need something to bypass the 2nd sensor and trick it to thinking its getting the right reading. I agree, I think it will happen less often with hi-flos than with decats but it will still happen IMO when the second sensor detects an unusual flow. The first sensor is not related since this is BEFORE the cat - its purpose is to provide fuel mixture feedback to the ECU (many times a second) so that fuel trims can be adjusted to keep the correct AFR ratio (nominally 14.7:1) Thats the one, you seem to say it a lot better than me. I finally got something right though Am i right in saying you need a MIL eliminator which is basically a transistor that sits on the second O2 sensor wire that causes the ECU to bypass that reading? Quote
Guest prescience Posted November 7, 2007 Posted November 7, 2007 This seems to be coming up quite a lot now from people who have fitted high-flow cats and i am still sticking to my intitial thoughts as it does effect emissions and the 1st and 2nd sensor are not showing the correct readings, hence the engine light comes on as it thinks there is a fault. You need something to bypass the 2nd sensor and trick it to thinking its getting the right reading. I agree, I think it will happen less often with hi-flos than with decats but it will still happen IMO when the second sensor detects an unusual flow. The first sensor is not related since this is BEFORE the cat - its purpose is to provide fuel mixture feedback to the ECU (many times a second) so that fuel trims can be adjusted to keep the correct AFR ratio (nominally 14.7:1) Thats the one, you seem to say it a lot better than me. I finally got something right though Am i right in saying you need a MIL eliminator which is basically a transistor that sits on the second O2 sensor wire that causes the ECU to bypass that reading? If this is what you mean then yes http://www.350z-tech.com/zwiki/Making_c ... simulators there are other solutions as noted above http://www.350z-tech.com/zwiki/Stop_CEL_With_Test_Pipes Quote
Mitchell Posted November 7, 2007 Posted November 7, 2007 The O2 simulator method looks a little complex! Is the idea of the later method just to move the sensors out of the flow of the exhaust gases? Anyone here actually done this? Quote
Tere Posted November 8, 2007 Posted November 8, 2007 I've never had an issue with my '03 Z. No lights with Random Technology high flows, and no lights when I gutted the high flows -- essentially they're now test pipes. Could it possibly be an issue in just the newer models? Quote
Zedrush Posted November 8, 2007 Posted November 8, 2007 I've never had an issue with my '03 Z. No lights with Random Technology high flows, and no lights when I gutted the high flows -- essentially they're now test pipes. Could it possibly be an issue in just the newer models? Hmm be interesting to see, Pingu what year is yours if you dont mine me asking mine is 2005 Quote
Guest prescience Posted November 8, 2007 Posted November 8, 2007 Is the idea of the later method just to move the sensors out of the flow of the exhaust gases? Yes. The O2 sim ensures the ecu gets a 'correct' reading but it is complex, the non-foulers is a cludge really Quote
Ian Posted November 8, 2007 Posted November 8, 2007 I've never had an issue with my '03 Z. No lights with Random Technology high flows, and no lights when I gutted the high flows -- essentially they're now test pipes. Could it possibly be an issue in just the newer models? Mine is a 2003 & I had a CEL with test pipes even with the nonfoulers in Quote
Ian Posted November 8, 2007 Posted November 8, 2007 UK car, I bought mine of someone that used to be a member on here with an 04 UK car & he never had any issues with a CEL (without non foulers) Quote
Tere Posted November 9, 2007 Posted November 9, 2007 Strange... Seems to be part of the whimsical nature of the Z. No apparent commonality at the heart of the issue. UK, JDM, US, or year model -- some do, some don't. Quote
Pingu2 Posted November 9, 2007 Posted November 9, 2007 I've never had an issue with my '03 Z. No lights with Random Technology high flows, and no lights when I gutted the high flows -- essentially they're now test pipes. Could it possibly be an issue in just the newer models? Hmm be interesting to see, Pingu what year is yours if you dont mine me asking mine is 2005 2004 Quote
