Rajzed Posted January 23, 2013 Posted January 23, 2013 Hey guys, Bit confused. Which oil can I use?? Handbook matches up with Castrol Edge 0W-30 and it also matches castrols recommended. Online seems to say any 5W-30, and halfords recommend 5W-30. Who do I listen to?? And does it really make a big difference?? Thanks in advance!! Quote
Rajzed Posted January 23, 2013 Author Posted January 23, 2013 Just ANY 5W-30?? Because the 5W-30 composition varies from each make and also the type? :S Quote
rtbiscuit Posted January 23, 2013 Posted January 23, 2013 Go to Opie oils, you can put in the car details and it will give you a car specific selection for normal and premium options Quote
ilogikal1 Posted January 23, 2013 Posted January 23, 2013 Go to Opie oils, you can put in the car details and it will give you a car specific selection for normal and premium options And there's members' discount to be had too. Quote
FUG Posted January 23, 2013 Posted January 23, 2013 http://www.350z-uk.com/forum/108-opie-oils/ 10% discount Quote
ZMANALEX Posted January 23, 2013 Posted January 23, 2013 This is the correct oil for your application. If you do not require the filter and crush washer then that is not a problem as I can sell just the oil on it's own. http://www.350z-uk.com/topic/66420-350z-engine-oil-service-kit-4695/ Alex Quote
