Hi,
Just had a look under my car, and I knew there was going to be rust as its a 52 jdm with 90k.
It's pretty rusty under there and I managed to take a picture.
Can someone identify the actual name of this part and how much a replacement is?
Many thanks.
I wouldn't have said that there is anything there that is terminal - it all looks to be surface corrosion.
Happy to be proven wrong if you can put a finger through it...?
I would take a wire brush or flap wheel to it and then give it a few coats of hammerite or similar after some rust proofer. Then top it off with some gravitex for good measure
Rear cross brace thingy :lol: dead technical :)
4 bolts drop it off clean and re-spray after rust treatment,
the bit above is part of the car (not removable) good clean and some rust seal maybe a spot of paint good to go :thumbs:
Agree with that. Purely cosmetic. Alternatively, just remove it and clean it up if you want it to look good again. Highly unlikely that it needs replacing.
Yours is so colourful! Ahah
Thank you.
Also, there is a brace the other side of the subframe. That's pretty bad aswell. Just again, drop that off and give it a good scrub?
That will be the "W" brace, same again clean rust seal and paint
Half sand blasted
Be warned it has a lot of 10mm captive bolts in it (Buster) snapped most of mine taking it off
I had to do some repairs to mine
and weld in new bolts
Under mine before the it got colourful :lol:
Hope it helps :thumbs:
Also, can the car be driven without it on?
Yes to the front one - not sure about the rear - it holds the rear subframe on I suppose you could put a big washer on instead?
I would NOT recommend driving without them -and certainly not hard cornering but should be OK to move the car around carefully.
Phew! I thought I was going to have to buy new ones! Lucky escape there!
Okay, cause I was thinking of getting them sandblasted which would obviously take a day or two.
Here it is mine off the car cleaned and painted,
All refitted it will look like -
Mines a 2003 :)
:thumbs:
It looks like Santas elves have gotten hold of the underside of your car :)
Mines a 2003 :)
:thumbs:
That has to be a calender picture Chris :thumbs:
  • 1 year later...
I have all the bits rust free if anyone needs them? The W-Braces rust through over time. thin I have 3 left.
How much do these go for? I don't know if mine needs replaced, but if the exhaust system is anything to go by I suspect the W brace was also manufactured by Cadbury's on behalf of Nissan.
