jumping350 Posted January 19, 2012 Posted January 19, 2012 Im spraying my Rota GTRs and was wondering if i could put my OEM 17 rears on the front without any bother while i get the fronts done?? couple of days on the car max Quote
Lexx Posted January 19, 2012 Posted January 19, 2012 Are they the same width and same with tyres? I cannae remember with the OEM standard wheels. Quote
jumping350 Posted January 19, 2012 Author Posted January 19, 2012 oem 17s on mine are rear 245/45/17 fronts 225/50/17 my Rotas are Rear 255/45/18 Fronts 235/40/18 Quote
Lexx Posted January 19, 2012 Posted January 19, 2012 And there is your answer. No. The TCS would go fecking bonkers as you are essentially flipping the rolling radious front to back. Quote
jumping350 Posted January 19, 2012 Author Posted January 19, 2012 il have to go pick the other two wheels up then even more missons now Thanks for your help buddy Quote
Beau Posted January 19, 2012 Posted January 19, 2012 It should be fine on a temporally bases. It will not hurt the car. You may have to drive with the traction control off for those days. Quote
Lexx Posted January 19, 2012 Posted January 19, 2012 Not wishing to be the H&S freak, but if you aint ever driven a RWD car without traction control, then I can't stress enough that you should not be experimenting with it when you have mis-matched tyre set up with narrow tyres on the back, and with wet/slippy roads. You would have to be fecking mental in IMO to do this regardless of your experience in the current weather conditions. But hey, it's your Zed, your insurance, and your life. Oh, and that poor fecker you run over when you lose control off a roundabout and mount the pavement. Quote
jumping350 Posted January 19, 2012 Author Posted January 19, 2012 im not going to do it but my rotas would still be on the rear of the car just the oems rear on the front..still sounds dodgy though and i know the TCS is a pain when it comes to this stuff Just out of interest if i swapped them over one wheel at a time but for the correct original oem 17 one would that cause it to play up also?? I just re read that sentence and ima numpoty that wouldnt be a problem cause the rolling radius would still be the same!!this always confuses me Quote
spursmaddave Posted January 19, 2012 Posted January 19, 2012 Not wishing to be the H&S freak, but if you aint ever driven a RWD car without traction control, then I can't stress enough that you should not be experimenting with it when you have mis-matched tyre set up with narrow tyres on the back, and with wet/slippy roads. You would have to be fecking mental in IMO to do this regardless of your experience in the current weather conditions. But hey, it's your Zed, your insurance, and your life. Oh, and that poor fecker you run over when you lose control off a roundabout and mount the pavement. I don't know about having miss matched tyres as badly as that but I drove through winter 2010/2011 with no TCS or ABS and I didn't fly off the roads in a fireball... I had never driven a RWD without traction control but I just did my commute to work sensibly and that was in all weathers, wet, icy even light snow until I had the chance to get to Abbey and sort things out. And before anyone says I am stupid if I had felt even slightly uncomfortable or unsafe I wouldn't have risked it for a second. What if I had a blow out and had to use my spacesaver, would I be fecking mental to drive home? I am pretty sure the space saver isnt 245/45/18 ? I'm not after starting an argument I just think it is a bit of an over reaction that's all Quote
Lexx Posted January 19, 2012 Posted January 19, 2012 I was just being devils advocate Dave, and making the OP think of possible consequences Quote
spursmaddave Posted January 19, 2012 Posted January 19, 2012 I was just being devils advocate Dave, and making the OP think of possible consequences And quite right too Like I said I don't know how bad it would be running different wheels / tyres etc as I am no expert and never been foolish enough to try it... also I always thought people who posted about turning of traction control to get a proper 'feel' of the car were complete knobs but I have to say when mine was faulty the car felt great I remember saying to Mark at Abbey that although the TCS/ABS and slip lights were on I had been driving the car for over a month and it felt fine so maybe it was faulty lights as the traction control MUST be working... He took the car for a 5 minute drive and told me with a huge grin that I had been driving with NO aids for definite Quote
DoogyRev Posted January 19, 2012 Posted January 19, 2012 I think as Dave says, if you drive in a sensible fashion, with the thought that your car is not at its most stable due to completely miss matched wheels and tyres, you will probably be ok. Personally, if you have a set of OEM wheels, just put all four on, it will only take you 20 minutes at most to swap them ALL over Quote
jumping350 Posted January 19, 2012 Author Posted January 19, 2012 I think as Dave says, if you drive in a sensible fashion, with the thought that your car is not at its most stable due to completely miss matched wheels and tyres, you will probably be ok. Personally, if you have a set of OEM wheels, just put all four on, it will only take you 20 minutes at most to swap them ALL over Yeah il prob have to just do that, 2 of the oems are at gf so will have to trek them back somehow just dont have a whole day to invest in doing all four at once Quote
marzman Posted January 19, 2012 Posted January 19, 2012 Do it, it'll be fine... But just incase. Quote
