Lucky GIT / Bonnet Struts
FIRST MOD OF THE YEAR!
Due to me being a Jammy git and winning Tarmac's raffle, I have a set of bonnet Struts!
:yahoo:
Just popped em on while I was touching up some bonnet chips.
I was worried that the bonnet wouldn't open as far with them on, as some photo's I have seen the bonnet looks "half open"...
But I had nothing to worry about, it opens about 1 or 2 degrees MORE than it does with the stay!
As you can see, the "stay" doesn't quite reach now :D
Will take some pics of the bonnet closed in a min.... Forgot to do that a min ago...
Pretty cool.... Just gotta take off the rear ones and get them sent off to be re-gased :snack:
very nice mod m8. :teeth: did you remove the bonnet stay bar from the zed as well. :thumbs:
Cheers... and at £7.50 a VERY cheap mod :teeth:
Nah...Gonna a leave the stay on. It is pretty light and would only clutter up the garage/get lost.
May as well leave it where it is :)
Say thank you to the man that started the raffle frenzy! ;) ......i.e. this one!
......Tarmac will do these at a discounted rate when I come to buy them though, eh tarmac! :D
Thye do look good.
Im not really a Carbon Fiber fan if im honest. But they are good quality CF...
Gonna take the stickers off them when it gets light. IF it doesn't SNOW! :thumbdown:
It look ME (and I am useless at this sort of thing) about 30 mins to do BOTH sides.
And it was like 2 degrees outside. Would have been ten mins each side if it was warm... and if I had the photo's I have now.
The install guide isn't great... but I figured it out. (Maybe I am just a little dumb!)
But you guys now have the photo's of mine showing you what goes where.
I can always take more photos... or even do an install guide. VERY easy to do!
(Edit: using the stay, it is a one man job, you can do one side at a time.)
We tried doing some on a mates astra years ago,and the hardest thing to do was getting the damn securing pins in at the top,took us hours!
These are simple, you slide the securing pin out (very good design) pop the joints onto the ball, then slide the securing pin back in and it locks onto the bar.
Simple, clever, easy install. :thumbs:
  • 1 month later...
On your own mate. Did mine alone. Put the bonnet stick in for the first side. Do the top ball joint, place the bottom fender bracket in place, remove the pin from the ball joint, take the bonnet stick out whilst holding the bonnet, pop the ball joint on. youll be holding the bonnet 2 seconds. Its safe now to do the other side :thumbs:
Looking good. I was looking at doing this myself and now want to do it more so as you say it opens the bonnet higher. Have you got a link to where you can get the same ones?
