9 second 1/4 Nissan for sale...
Interesting....
Fuel:
Bugatti Veyron Fuel Pump
Bet it's fun on the drag strip....
One minute you're listening to The Foo Fighters on the radio, then next thing you're doing warp speed!!!
I guess that's not a daily driver :lol:
Interesting....
Fuel:
Maybe that explains the price!
It's his daily driver....
Whats the power i cant seem to view that page in work????
Look at the size of the blower :scare:
stating 1000hp fly... different whp and different hp on different gas/map... I'll get the nr...
This is your chance to own a record-holding 350Z with an incredible setup that you won't find anywhere else. This car is an amazing performer, and still maintains nice street drivability.
2005 350Z, Touring, 57k miles
Black exterior with black leather interior, heated seats, aftermarket Navigation.
1000+ HP! (772WHP DD on 116oct, 613WHP DD on 93oct)
9.3 @ 148mph 1/4mile on DOT tires. Has been raced less than 5 times - running 9.8 at first event and 9.3 at second event.
This Z is in overall good condition, with regular front-bumper rock chips in line with the mileage. ~2500 miles on this setup that was properly broken in and extremely well taken care of.
Engine (VQ35DE):
* 3.5L VQ35DE, 8500rpm redline
* CP Pistons (8.5:1 cr), Eagle Rods
* HKS Stopper Head Gaskets secured by ARP L19 Head Studs
* Injected Performance Billet Main Girdle with ARP Main Studs
* Brian Crower BC Stage3 272 Cams, Valve Springs, Retainers
* Cosworth Intake Plenum
* Injected Performance Custom Single Turbo Kit
* Garrett GT42R Ball Bearing Turbo
* 4inch Burns Stainless Steel V-Band Exhaust w/ Burns Muffler
* Greddy Intercooler w/ Aluminum Piping
* HKS 60mm Wastegate & Tial 50mm Blow Off Valve
* Custom Saldana Aluminum Radiator
Fuel:
* Bugatti Veyron Fuel Pump
* Injected Performance High Flow Fuel Rails
* Aeromotive Fuel Pressure Regulator and 10AN Fuel Feed
* VP Race Gas for High Boost
Drivetrain/Suspension:
* 6 Speed Manual Transmission
* Tilton Triple-Disc Clutch and Tilton Lightweight Flywheel
* Driveshaft Shop DSS PRO Axles, NISMO Extended Wheel Studs
* B&M Short Throw Shifter
* LSD Differential
* Injected Performance Bolt-On Dif Brace
* Injected Performance Solid Motor Mounts
* MR Coilovers, SPL Camber Arms, Toe Bolts
* Injected Performance Driveshaft Loop
* Dual Line-Lock setup retaining ABS/VDC
* Lightweight 18" wheels with MT 305/35-18 Drag Radials
Electronics:
* Haltech Platinum PNP Standalone Engine Management
* Haltech Mapped Boost-by-Speed Control
* Haltech Wideband O2 Sensor
* Tuned by Hal @ Injected Performance
$44,500
Available for immediate purchase.
is that a typo? :disguise:
Now that I like - avoiding the temptation to add external mods to give the impression it is anything other than standard. B)
^ Like the way they've move the strut cage at the front of the car (black)
thts cheap, the motor would cost more then that to build.
front cross member (rad support) they used to be made by some one makes fitting larger rads far easier.
nice car thou. hand full as a daily driver thou I think
made by someone in the UK or accross over there? Not sure it's only the engine that involves those costs... here is a vid of him on the road :surrender:
http://www.youtube.com/watch?v=s9mdtyQ1x8U
Built in the US
Yeah, is that no good then? :blush:
As Abbey's Project ZED shell was originally built in the US that should answer your question ;)
