Petrol tank flap not opening
M9O OEY
i had this myself also on the second time off filling up my 350z
press - check
press - check
repeated this like 10 times, i looked like a right muppet, it eventually opened. and since then not been an issue, but i may have to do what was said above and just clean and grease it up.
not the same issue, but similar, i pushed the button on the dash to open my petrol cap and pushed the button in... :S
If i cant get this back out, how else can you open the petrol cap? or can't you?
I pushed mine through as well, you can easily get access to where you have pushed it through and then replace back into position. If you get down into your footwell you will see it. :thumbs:
