seasider Posted December 18, 2008 Author Posted December 18, 2008 Alex, apologies if I came across as not taking the advice on board. I definately did hence my confirmation with the garage on the unit being dead and the diagnostic procedure listed on an earlier page being followed. I am also in a poor mood at the moment because of the cost so that may have inadvertantly come across in my messages. I am very appreciative for the advice given on this thread. I was simply trying to explain that the unit had been confirmed as dead. I have the same cynicism with the ECU being the cause of the problem as Nissan also told the garage that they have never had to replace an 350z ECU for a manufacturing fault. However the ECU is now dead so my worry is that the ECU has been damaged by a jump start. If this is the case it was either the recovery guy or me that did it. There were no sparks when jumping so i guess all that could have happened is a voltage/ampage overload from the other car when jumping. Therefore there will be another fault once we fix the ECU. Thanks for all the advice and if it turns out I am the first person to have a genuinely failed ECU unit I will post on here to let people know. Quote
flirt Posted December 18, 2008 Posted December 18, 2008 i have the old ecu from mine if your after one cheap Quote
GIXXERUK Posted December 18, 2008 Posted December 18, 2008 my worry would be if the ecu is fried then did it just fail or has something fried it Quote
H5 Posted December 19, 2008 Posted December 19, 2008 my worry would be if the ecu is fried then did it just fail or has something fried it +1 That would be my concern too... Quote
Ebized Posted December 20, 2008 Posted December 20, 2008 I have the same cynicism with the ECU being the cause of the problem as Nissan also told the garage that they have never had to replace an 350z ECU for a manufacturing fault. However the ECU is now dead so my worry is that the ECU has been damaged by a jump start. If this is the case it was either the recovery guy or me that did it. There were no sparks when jumping so i guess all that could have happened is a voltage/ampage overload from the other car when jumping. Therefore there will be another fault once we fix the ECU. Thanks for all the advice and if it turns out I am the first person to have a genuinely failed ECU unit I will post on here to let people know. I don't know is this might help you with your case but in the owner's manual (2006 version) at 6.7 to 6.9, it tells you about jump starting and there is certainly no suggestion you shouldn't do it or damage being caused to the car - just the usual cautionary procedures about the process. Quote
Stew Posted December 22, 2008 Posted December 22, 2008 It is a very strange situation. Zmanalex probably knows more about the 350Z than most in NMGB. I don't say that lightly either! I am glad you trust your Nissan dealer so much as to entrust them with fitting a new ECU to a car that could still have a fault which could cost you the same amount of money again. I wouldn't trust any one party on a diagnosis of this scale especially with the information that no other failures have been reported. I would be taking it for a second if not third diagnoses even with the evidence that has been reported and witnessed. Perhaps I am a fool for being the way I am though....... Quote
matth76 Posted January 25, 2009 Posted January 25, 2009 I'd be interested to know if this was resolved too. Quote
AUTO EXPRESS Posted January 25, 2009 Posted January 25, 2009 i have used R35LEE. a great person to deal with. just supplied me with two rad fans.good price & correct postage Quote
wizard Posted February 26, 2009 Posted February 26, 2009 Btw, guys I have had the same problem which was documented on the **REMOVED** forum... Pretty much the exact same thing happened as described here. It was over £1500 for a new on IIRC... Just a note: If you buy a second hand ECU, it will PROBABLY not work because it is not suited to your particular Zed model. Mine is a 2002 JDM and I tried installing 2 of Alex's ECUs... Neither of them started the car. I later discovered that there are over 13 different types of ECUs for the Zed and if you do not get the correct one, then it WILL NOT work.. So if anyone has this problem again, tread with care! Quote
