Rob189 Posted January 1, 2025 Posted January 1, 2025 Hi guys Ā New to forum and also only recently became a Z owner (about time). Been using this forum a bunch to help solve all the small problems that Iāve encountered already. Without you guys iād probably still be struggling my way through the first issue š Ā As the title states, Iām struggling with the auto up feature on my passenger window. Iāve tried the following: 1. Window switch reset procedure (by pressing that little black button and opening the window - from the guide on this forum) 2. checked the door closed switch (interior lights of the car switch off when I close the door - so it must be good?) Ā This is what happens: I open the door, the window drops down a bit. I close the door, nothing. I open the door again, it drops down by the same amount. I can keep doing this until the window is fully open. Kinda funny, but gets tiring real quick. Ā Ā Note: window operates perfectly when using manual controls. Also, not sure if this helps in any way, but the passenger window seems to drop down about double the distance that what the driver window does when you open the doorĀ Ā Canāt seem to find any other info on what I can try next. Any guidance would be appreciatedĀ Ā cheers Rob Quote
ShortPaul Posted January 1, 2025 Posted January 1, 2025 Hi buddy have you tried replacing the window motor? Quote
Rob189 Posted January 2, 2025 Author Posted January 2, 2025 9 hours ago, ShortPaul said: Hi buddy have you tried replacing the window motor? Motor seems to operate perfectly when using the window controls (up and a down). Itās super smooth. Ā The issue must be related to the controls (either a switch that Iām unaware of, orā¦) or possibly related to not do the window switch reset correctly (I donāt fully trust that little black button that you must hold in) Ā Is there any particular reason for suggesting the motor replacement, or is it more of a ājust to rule it outā suggestion? Reason for asking - I want to try all the free options first before spending any, hopefully unnecessary, money of the car. Ā Ā Quote
ShortPaul Posted January 2, 2025 Posted January 2, 2025 (edited) Hi mate,yes its just a rule it out questionĀ Edited January 2, 2025 by ShortPaul Quote
Stewal Posted January 5, 2025 Posted January 5, 2025 (edited) Are you sure it's supposed to auto up on the passenger side: mine doesn't.Ā Ā It's auto down both sides auto up drivers only. Ā Ah forget that: just misunderstood op! Ā Ā Edited January 5, 2025 by Stewal Corrections Quote
mr v6 Posted January 5, 2025 Posted January 5, 2025 47 minutes ago, Stewal said: Are you sure it's supposed to auto up on the passenger side: mine doesn't.Ā Ā It's auto down both sides auto up drivers only. Ā Ah forget that: just misunderstood op! Ā Ā Odd, as my drivers side is auto up & down as per the 'A' on the switch, but the passenger side is not auto up or down. I'm sure that's how they are. I did read on here a few years ago that getting a drivers door switch with both switches being 'A' auto, meaning both windows are auto, but that left the switch permanently live once the ignition is turned off. Quote
Stewal Posted January 5, 2025 Posted January 5, 2025 I wonder if the difference is roadster v coupe as the windows drop for the roof operation.Ā Quote
Rob189 Posted January 5, 2025 Author Posted January 5, 2025 3 hours ago, mr v6 said: Odd, as my drivers side is auto up & down as per the 'A' on the switch, but the passenger side is not auto up or down. I'm sure that's how they are. I did read on here a few years ago that getting a drivers door switch with both switches being 'A' auto, meaning both windows are auto, but that left the switch permanently live once the ignition is turned off. By āauto up/downā Iām not referring to the switch features where you pull the switch all the up/down to have to window fully open/close itself.Ā Ā Iām referring to the scenario where the window automatically opens a little bit when you open the door and then goes back up after youāve closed the door.Ā Ā The issue is that this works on my drivers side door, but on the passenger side the window goes down but doesnāt go back up when the door is closed.Ā Ā Hope that clears up the confusion a bitĀ Quote
Rob189 Posted January 5, 2025 Author Posted January 5, 2025 1 hour ago, Stewal said: I wonder if the difference is roadster v coupe as the windows drop for the roof operation.Ā Iād imagine that feature will be the same for all models as its purpose is to protect the window from damage when closing the doorĀ Quote
Coz@TORQEN Posted January 6, 2025 Posted January 6, 2025 To reset them, just use the normal window buttons, start with the windows full closed.Ā Ā Hold the button down to open the window, keep it held until you hear a click (15 secs or so), then do the same going up - hold it up until you hear a click.Ā Ā Do the same on both sides and this should fix your issues.Ā Ā Ā 2 Quote
Rob189 Posted January 7, 2025 Author Posted January 7, 2025 On 06/01/2025 at 13:08, Coz@TORQEN said: To reset them, just use the normal window buttons, start with the windows full closed.Ā Ā Hold the button down to open the window, keep it held until you hear a click (15 secs or so), then do the same going up - hold it up until you hear a click.Ā Ā Do the same on both sides and this should fix your issues.Ā Ā Ā No luck Iām afraid. Thanks for the input thoughĀ Quote
heterofrogs1 Posted January 7, 2025 Posted January 7, 2025 Might be worth a deeper look in the FSM, I had a quick gander and there's some troubleshooting steps that may help point you in the right direction.Ā Factory Service Manuals - NICOclubĀ (page GW21 onward)Ā Quote
Rob189 Posted January 11, 2025 Author Posted January 11, 2025 On 07/01/2025 at 18:42, heterofrogs1 said: Might be worth a deeper look in the FSM, I had a quick gander and there's some troubleshooting steps that may help point you in the right direction.Ā Factory Service Manuals - NICOclubĀ (page GW21 onward)Ā Thank you very much! That manual is exactly what I need.Ā Ā Will report back when/if I can fix the problemĀ Quote
Rob189 Posted October 19, 2025 Author Posted October 19, 2025 So. I finally got around to looking at this issue again.Ā Ā Turns out that the problem was the limit switch on the window motor assembly . The switch died, which led the controller to believe that the window was always closed. I replaced it with a temporary limit switch and problem solved.Ā Ā P.S. The limit switch is a Panasonic AV44-C for anyone that doesnāt want to buy a whole new assembly.Ā https://za.rs-online.com/web/p/micro-switches/1738405 Quote
