Sign in to follow this
avado
Both windows not dropping a little
Hello guys,
I need some help with this problem.
Both windows not dropping a little bit when l'm going to open each door. But when I open the door and manually push the window down after that it closing perfect.
I tried to reset them manually by open and closing fully the windows without success.
The left window motor is soon repaired so I think the problem is not in the motors. I made a video:
Kindly asking moderator to move this topic in the 350z forum.
Edited by avado
Share this post
Link to post
I would first check the door switches on the b posts. Then carry out a window auto up/down reset.
Share this post
Link to post
As above, check the door switch (nipple). Whilst your door is open, you can press/release the switch to check if your windows are moving. I take it your window will go fully up and down without issue? If they are working well, then i would do a full reset ie removing door card
Share this post
Link to post
Loading...
350z-uk.com
370z-uk.com
