LRF4N Posted April 22, 2018 Posted April 22, 2018 How long did it take you to remove the fans? Need to motivate myself to do mine, had overheating issues and checked the fans, no life in them Gonna try cleaning the motors out as per Colin’s thread above Quote
burntorange Posted April 23, 2018 Author Posted April 23, 2018 Taking out the fans doesn't take that long its just fiddly as you have to work it around certain objects either to the left or right of it and then at the top where the top rad hose neck is and the filler cap. I hope you have more luck than i did doing this as mine went up in smoke. Quote
burntorange Posted April 23, 2018 Author Posted April 23, 2018 Update!!! I passed the MOT....whoop whoop.... Took a while mind...had the emissions tested 3 times over before it actually passed though... Was failing on the lamda....guessing down to the big bore on the end.....so they took the clip on end off and shoved the pipe further into the exhaust and then it passed.... Thank god.... So for now my worries are over!! 1 Quote
burntorange Posted April 23, 2018 Author Posted April 23, 2018 No advisories either which is great, everything is solid! and i will say your(readers) god as then it pleases everyone Quote
Ebized Posted April 23, 2018 Posted April 23, 2018 Glad you got it sorted and had a helpful MOT tester Quote
burntorange Posted April 23, 2018 Author Posted April 23, 2018 Thanks everyone for all your help its been much appreciated Quote
heyho Posted June 22, 2018 Posted June 22, 2018 So I have the same issue so I am replacing the thermostat and temp sensor and going to bleed. Fingers crossed. If not then will replace the fans but at around £200 for a Mishimoto replacement is it likely to be that and is it worth replacing? Quote
