JwBye19 Posted January 23, 2016 Posted January 23, 2016 My pads are wearing low on the front and with a trackday looming they need replacing, not a clue what pads are on it but the discs appear to be DBA, with little wear. The rear looks stock. The question is, can I put yellow stuff pads on the front without touching the rear? Quote
ZMANALEX Posted January 23, 2016 Posted January 23, 2016 The answer to your question is yes. However best to pull the rear pads for a proper inspection, especially the inside pads. Quote
JwBye19 Posted January 23, 2016 Author Posted January 23, 2016 The answer to your question is yes. However best to pull the rear pads for a proper inspection, especially the inside pads. Thanks for that mate, what about brake balance or won't it affect it that much? I'll certainly be having a look though, fluid flush and braided lines to fit Quote
GMballistic Posted January 23, 2016 Posted January 23, 2016 If you're doing the brake fluid as well I'd recommend Motul RBF600 brake fluid ~ it's what I used to run with my Zed and seemed to work very well with the set up I had on trackdays/fast road driving. Link: http://www.h-dev.co.uk/product_info.php?products_id=25423 Set up was: EBC Turbo Groove discs, Ferodo DS2500 pads & Goodridge braided stainless steel brake lines with the Motul RBF600 fluid. Quote
Ekona Posted January 23, 2016 Posted January 23, 2016 It's okay to send brake bias forward a touch with pads and discs, it's sending it to the rear where you can have major issues. You'll be fine. Quote
Jakeswheelbarrow Posted January 23, 2016 Posted January 23, 2016 EBC red stuff pads are highly recommended Quote
JwBye19 Posted January 23, 2016 Author Posted January 23, 2016 I've got HEL lines and ate typ200 racing fluid going in Quote
davey_83 Posted January 23, 2016 Posted January 23, 2016 What happen to my red stuff on my ol Almera GTi Quote
simcoep Posted January 23, 2016 Posted January 23, 2016 Seen that happen to a few sets of ebc pads, apparently this issue was rectified how ever I run yellow stuff and have had a couple of other sets on other cars and seem ok Quote
veilside z Posted January 25, 2016 Posted January 25, 2016 I run the Ferrodo DS2500 Pads and are great. Quote
ZonixX Posted January 26, 2016 Posted January 26, 2016 (edited) if you want ultimate braking performance and would be willing to live with very noisy brakes eating through your rotors quite fast, I can recommend Ferodo DS1.11 ...they are brutal Edited February 6, 2016 by ZonixX Quote
brillomaster Posted January 26, 2016 Posted January 26, 2016 we normally run yellowstuff on our track bmw, would recommend them over redstuff as redstuff aren't really beefy enough for track work in a heavy car like the zed. great for road driving through. Quote
