Help removing unusual scratch in bumper
James Junior
So, I was out for a spin in the Pyrenees the other day - as you do - when a herd of sheep came up the road. So. Many. Sheep:
12004682_10156133420195195_1831138826126308574_n.jpg?oh=85e4d4f8b87ec267d809e786cf30a6f1&oe=56A202EE
Unfortunately a couple of the rams scraped their horns down the bumper of my car causing this:
12032206_10156144824275195_2580029038494992570_n.jpg?oh=cf228498cfa90550914a2e99df554055&oe=56A4C95B
11014971_10156144824265195_3731497944209848690_n.jpg?oh=8c49173ef852e3a55ddb488a2c385862&oe=56A79671
I had a go at it with some Auto Glymm polish which improved it a bit, but not much.
I am not very experienced when it comes to detailing and wondered if anyone could recommend any products and / or techniques that might improve it without me having to get the bumper painted?
Any advice would be gratefully received!
You should be able to tidy that up a bit at the very least.
You will need a tangerine one of these with a bit of this and a fair amount of this, removed with one of these.
After that, you'll need a crimson one of these with a bit of this and more of of this, removed with another one of these.
Then when you're both happy that you've achieved all you can achieve and you're absolutely knackered, you can get your AutoGlym Polish (which isn't actually a polish, hence it didn't do much) out and fill what you can't polish out and then wax/seal on top.
Better still, get one of these with the DAS-6, put on your big boy pants and learn a new skill.
Or alternatively get yourself one of these.
I'd hazard a guess from the pictures that you might struggle to get it perfect without paint but you can certainly make it less noticeable if not near perfect just by polishing it out.
Thanks for taking the time to post all that Ilogikal, I will have a look through tomorrow and do some online shopping.
I had looked at getting an orbital polisher once before. Perhaps it is time...
Zmanalex - well it was certainly the most unusual circumstances anyway! At least it makes a change from some mouth breather bumping into it in a supermarket car park.
If its just scratched the clear coat, which it looks like it has, you can touch in the lacquer.
Remove any wax or polish that is now in the grooves of the scratch with some spirit, tar and glue remover or acetone. Buy some lacquer and thin it down so its like water, then very carefully fill in the scratch using thin layers and a very fine brush, let each coat dry and build up the groove slowly. Only get the lacquer in the groove dont let it build up on the edges around the groove. Let it all dry, then polish the bumper and it should be almost invisible. :)
