Dicky Posted May 12, 2015 Posted May 12, 2015 I'd appreciate it if any locals can recommend a good body repair shop in Newcastle or surrounding area. I've already been to Premier Motors near Crosslings off the coast road but looking for another comparative quote. Quote
Dicky Posted May 13, 2015 Author Posted May 13, 2015 Tell me I'm not 350Z-Uk's only Geordie member ! Quote
martinmac Posted May 13, 2015 Posted May 13, 2015 I had a fair bit of work done when I had my car modded by esr. They used a company in Sunderland if that's not too far away. Quote
martinmac Posted May 13, 2015 Posted May 13, 2015 I used car and bike magic in Sunderland a lot of that's not too far away. Quote
Lexx Posted May 13, 2015 Posted May 13, 2015 Car and Bike Magic reputation isn't what it once was. Falcon Performance on Teesside are good. You could call Jurgen at JM Imports and ask who he uses. 1 Quote
Dicky Posted May 13, 2015 Author Posted May 13, 2015 Sunderland isn't far away at all. I've never heard of Car & Bike Magic before but have heard good things about Falcon for clutch changes. I'll get in touch with both and see what they say. Thanks for your input lads. Quote
Jay M1988 Posted May 13, 2015 Posted May 13, 2015 Mirror finishes in byker is who i use for all bodywork needs. 1 Quote
nowhereboy Posted May 15, 2015 Posted May 15, 2015 Heard a lot of good stuff about mirror finishes! And no you're not the only newcastle member Quote
Toon Chris Posted May 15, 2015 Posted May 15, 2015 (edited) Car and Bike magic did an outstanding job for me, but true that was a few years back now. https://www.facebook.com/pages/Car-Bike-Magic/529504360399270 Edited May 15, 2015 by Toon Chris Quote
Dicky Posted May 18, 2015 Author Posted May 18, 2015 Just to update, rang Falcon first and was so impressed with the body shop managers experience of treating this problem. He's done loads of 350's and seemed to know the fix options inside out. Leaving out the obvious perminent fix of replacing inner and outer wings his prefered solution is to cut out the rust, bead blast any rust he can get at, treat with anti corrosion spray, weld in new metal, seal the joint between the inner and outer panels with a resin stopper, then respray. It's not a perminent fix but if looked after will outlast any other fix. Cost between £1K & £1.4K depending on how bad the rust is. Quote
