Hi all,
I own a 2005 350z @ 95000miles
Fitted a manifold back exhaust and ever since I get a large puff of blue smoke (oil) when blipping throttle in neutral or when pulling away from a junction after coasting to a stop.
Doesnt happen all the time though.
I am leaning toward breather system but wanted to check if anyones had similar issues.
Thanks
Lol, not quite what I meant. What causes this sudden puff?.
Is there a way to eliminate it?.
Is it wise to upgrade the OEM breather system to cope.
Or, in all likelyhood my rings are shot and I`m doomed?
Sorry should of worded it that way first time.
It's part of the maintenance on z engines that you change the breather value off the top of my head its 74000 service that it gets done .Make sure you keep an eye on the oil level .
When you removed the oem cats you also created a passage for the oil to exit.
You did not see it before because the oem cats burnt it up.
At 95k I suspect that you will be using a bit of oil
However you will be using the same amount of oil as before and if that was not excessive then all will be good.
I should expect the same on my 370z then now decat. ......and a supercharger
Yep - get the odd little puff from mine ;)
