bencider Posted April 13, 2015 Share Posted April 13, 2015 All the above lights have stopped working. Went to change bulb in boot and it didn't work .. now the dome lights and the green flashing lights for indicators not working. I also noticed when u put side lights on that light on dash does not come on.. can't find the blown fuse.. any one know? Â Thanks Quote Link to comment Share on other sites More sharing options...
techinstaller Posted April 13, 2015 Share Posted April 13, 2015 (edited) check your fuses under the bonnet located under the panel by battery and the small fuse box near the accelerator pedal behind the little panel if no fuses are blown ,i suspect a possible BCM fault .I hope not as they are not cheap if this is the case it may be repairable as there is a common fault which is a burnt track on the circuit board i have worked on one before and think i have the information somewhere if it does turn out to be the problem Edited April 13, 2015 by techinstaller Quote Link to comment Share on other sites More sharing options...
bencider Posted April 13, 2015 Author Share Posted April 13, 2015 Thanks for reply .. what fuse am I pulling.. there is loads half of them are not on the diagram Lol. What the heck is a bcm it defo sparked on putting the new bulb in then all dead Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 13, 2015 Share Posted April 13, 2015 BCM =  In automotive electronics, body control module is a generic term for an electronic control unit responsible for monitoring and controlling various electronic accessories in a vehicle's body. Typically in a car the BCM controls the power windows, power mirrors, air conditioning, immobilizer system, central locking, etc.   Hope that helps   No idea which fuse - check em all Quote Link to comment Share on other sites More sharing options...
bencider Posted April 13, 2015 Author Share Posted April 13, 2015 Ha ok thanks. Quote Link to comment Share on other sites More sharing options...
veilside z Posted April 15, 2015 Share Posted April 15, 2015 Deffo do the fuse check first. Worst ones to get to are under the nearside window scuttle panel. Quote Link to comment Share on other sites More sharing options...
veeg33 Posted April 15, 2015 Share Posted April 15, 2015 (edited) +1 on checking fuse. Try to reset by disconnecting the battery and reconnect again. Â I change my interior bulbs to LED last year and somehow managed to short circuit my zed where most of my interior electronics stopped working (windows, electric seat, seat heater and central locking). However by disconnecting the battery only fixed it temporarily. I ended up going to Nissan dealership for a factory reset and it all works again. Â So hopefully the 'spark' you mentioned temporarily screw up your BCM. Â Have a read here to reset interior lighting - http://www.350z-uk.com/topic/51881-interior-lighting-reset/ Â Let us know how you get on and good luck Edited April 15, 2015 by veeg33 Quote Link to comment Share on other sites More sharing options...
bencider Posted April 17, 2015 Author Share Posted April 17, 2015 Ok thanks,, prob I have is location of the fuses.. been working away all week so not looked yet Quote Link to comment Share on other sites More sharing options...
bencider Posted April 18, 2015 Author Share Posted April 18, 2015 Can't find any blown fuses so I guess it's the bcm, can this be fixed or needs replacing. Quote Link to comment Share on other sites More sharing options...
cs2000 Posted April 19, 2015 Share Posted April 19, 2015 (edited) Tried the BCM reset?  oth windows down, open both doors, disconnect battery earth lead. Wait five minutes until BCM resets itself, reconnect battery terminal and viola we have lights in the interior again.  Otherwise, somewhere their is a post about repairing the BCM. Its a single track that gets fried and you can bridge it with some wire. Alternatively yeah it's a replacement needed. I'm pretty sure you can use any BCM from any 350 however, you don't need a "box fresh" one from Nissan  EDIT: found the guide http://www.dmcauley.com/350z/BCM_repair_350z_UK_2004.pdf Edited April 19, 2015 by cs2000 Quote Link to comment Share on other sites More sharing options...
bencider Posted April 19, 2015 Author Share Posted April 19, 2015 Thanks will check this guide out,, yea went and read some posts from search did a reset but nothing.. Can't believe some electrics can be this sensitive..now my dad's saying " you will have these expensive cars " haha Quote Link to comment Share on other sites More sharing options...
bencider Posted April 19, 2015 Author Share Posted April 19, 2015 I'll just add from reading the pdf. that my lights dont work if I press them manually either if that matters.. I guess it's no big deal to open the bcm up anyway Quote Link to comment Share on other sites More sharing options...
bencider Posted April 21, 2015 Author Share Posted April 21, 2015 So pulled out the bcm, took it apart and found no problems, frustrated at this point and with the fuses box hanging down I grabbed my meter and could not believe it,, a fuse WAS blown.. looked fine to look at as it blown at one end.. unbelievable... Changed fuse plugged everything back in and all working again .. Will meter all my fuses next time lol 3 Quote Link to comment Share on other sites More sharing options...
veeg33 Posted April 21, 2015 Share Posted April 21, 2015 Glad it's all sorted out now! 1 Quote Link to comment Share on other sites More sharing options...
Ziptieordie Posted June 18, 2019 Share Posted June 18, 2019 Sorry to resserect a very old thread but these exact symptoms have just happened to me and I was hoping to know what fuse this was that blew? Quote Link to comment Share on other sites More sharing options...
veeg33 Posted June 19, 2019 Share Posted June 19, 2019 14 hours ago, Ziptieordie said: Sorry to resserect a very old thread but these exact symptoms have just happened to me and I was hoping to know what fuse this was that blew? Check all them as it wasn't mentioned, there isn't many of them. Quote Link to comment Share on other sites More sharing options...
Ziptieordie Posted June 19, 2019 Share Posted June 19, 2019 Just for anyone else who has this issue in the future turns out the fuse pictured had blown in the fuse box down near the pedals. Quote Link to comment Share on other sites More sharing options...
