gear knob removal
embrace
as daft as it sounds my gear knob is completely stuck on..
anyone got any tips in removing it without snapping the gear leaver off? ive done a quick forum search but surprisingly couldnt find anything dont suppose anyone has had this major problem before LOL
Grip the shaft with some mole grips (protect the shaft with a tea towel or similar), then tighten the knob by hand first then try loosening it. As long as you're holding the shaft, you can be as aggressive as you want: You won't break anything.
Be prepared for the oem knob to get damaged
Mine ended up in 3 pieces
Had to use a pair of grips on the shaft and a bigger pair of grips on the gear knob (wrapped in a towel) unfortunately it wouldn't budge so enlisted help from a pal, I held the grips on the shaft while my pal twisted the gear knob. Lots of loctite holding it in place and unfortunately it split under the force
Lots of swearing but we eventually succeeded however the oem knob was toast by the time we got it off
Edited by tatooandy67
