Hi guys I'm in the middle of my turbo build and I'm just working out the fuel system.
I've got an updated walbro pump and I'm thinking of doing a return system to cope with the added boost. All I'm stuck on is wether I can just come off the fuel rail damper with a an fitting and loop it back into the tank?
Also I read that you need to swap the fuel regulator inside the tank so that the pump can suck up from both sides and not run lean at a 1/4 tank.
Any light shed is appreciated.
I have just emailed charles as seen quite a few bits of his on the my350z site.
As for turbo kit i picked up a JWT twin kit cheap but obviously ran into manifold trouble so currently im adapting & fabricating some tubular low mount manifolds to adapt them for fitment :-)
No build thread as yet maybe i should start one soon ha
+1 on what Adrian said but even a stage o will do with decent injectors like the injector dynamics 725cc or 1000cc assuming your goal is for under 550whp.
Edited by GT4 Zed
I'm not after a 370 kit I'm putting it on a 350 :-) stage 0 kit will be what I go for but il try and build the kit myself I deal with a hose company at my work and they should be able to make it all up. Only thing I think I will have to buy is the fuel pump regulator for the tank pump line
Also a thought can the pump regulator in the tank be drilled out and tapped for a an fitting? This would just be quicker then me having one made
i made myself all the fuel return system. its like a stage 2 and all that you need is a new pump and a new regulator.
search the forums and go to jim wolf tecnologies site, its all there!
