vibration at front left wheel
Garyt350z
I'd say warped disc. There's a member on here who does disk skimming. Someone will post his username I'm sure. (Awkward to find on my tablet)
You can buy a guage that checks the run out on the disks. They are called dial tests indicators I believe.
This happened to me. I won't say it's not a warped disc 100% but it can also be that you need to grease up your caliper retaining pins. This solved the problem for me. If I had gone and swapped my rotors I'd be out lots of $, so it's always good to eliminate options.
Edited by ryanmackk
  • 3 weeks later...
