Power steering whining noise
GT Driver
Anyone else experience this?
I notice it when turning the wheel when stationary or moving very slowly such as 3 point turn. Whining noise starts when turning the wheel and it's slightly louder when on full lock either side. The power steering itself appears to be working fine with no real resistant. Just the whine is annoying me.
Have checked the fluid - no leak noted and is sitting on the 'cold max' line when cold. I have not had to top up.
Any ideas where to start... would a fluid change be likely to help?
It's the pump under load turning when stationary is heavy load - well heavier than when moving and you can here it - and full lock is maximum load so the oil goes through the valve faster - more nosie
You can change the fluid and bleed the system it may help but it's most likely a bit of wear - doesn't mean that there is anything wrong with the pump, I've heard low mileage nosier ones and high mileage ones that are still whisper quiet.
Busters got noisy at one point so we changed the oil and it's been pretty good ever since :thumbs:
  • Like 3
Is there a drain plug on the rack? I'm about to do this over the next couple of weeks...
No drain plug, so just got to take a hose off at the reservoir and also the cooler if you want most the old fluid out.
Alex. :)
