I've purchased a zunsport grille,says it should be straight foward fit just screws in.in the instructions it says screw in the screws to the brackets and job done,now I have no brackets for it to screw into.when looking closer I notice I could remove a plastic section and behind there is a metal ring.im now wandering if that ring is the towing eye and if I have bought the wrong grille,can anyone help and if someone with the towing eye grille can tell me if it comes with brackets
Is it a facelift or pre facelift? I had the pre facelift and got the one without the towing eye. Just got it into position and screwed it in,,, doesn't come any easier. I think the facelift is much harder though, remember someone saying you have to remove the grill but don't quote me on that :thumbs:
I have a 2004 and mine just screwed into the black plastic that sits behind the grill ( not that easy to see )
Dead easy fit - offer it up into position - screw in the screws - no brackets required ...
easier if you have help to hold in position whilst you do the screwing
As others have said, it hooks into the bumper near the number plate and screws into the original grill (Once you've removed the front pieces - don't want to leave holes in these!)
You can just about see the holes in the above and highlighted green below (Facelift version).
Prob a silly question but what are the differences between facelift and pre facelift
facelift came out in 2006 ... power up from 280 PS to 300 - front bumper changed - headlights upgraded - LED rear lights - interior better finishes etc.
on the down side road tax goes up
