Hey my oil psi is getting very low. Around 10 to 15 on idle. Been 15month since service, I know, overdue. But is this a valid reason why its dropped from my nornal 30 to 35?
Check the oil level. That's the only thing that's important.
As long as the gauge reads between zero and max, that's generally perfectly fine.
Ive not done many miles since last service, maybe 7 or 8k. But still been a long time :/ ill check oil pressure tomorrow, I might do oil change til I get p3 at end of the month.
When I turn steering wheel 180degrees with clutch in while driving the oil light comes on jntil I straighten wheel. Not sure if that means anything.
With the p3, am I able to do that myself, or is it too difficult? Got no money for p3 atm but I di need p1 just now I think
If you cant be bothered or can`t afford to check the oil level then you probably shouldn`t be driving the car. Normally if the oil light shows when running you have already done more than enough damage than the cost of a litre or 20 of oil :scare:
Edited by Darren-B
:scare: :scare: that cant be good. you must check it as soon as possible!
It's not burning any Dean as i followed you last saturday for about 15 miles back from Brighton and not a wiff of oil.
I did have a car do that to me.
It was a ex police Rover p6V8. It used a litre of oil a day.
You knew when it wanted topping up as when you go round a bend the oil light came on as the oil slopped about.
I thought though does occure.
Has it got an extended oil pan? And if so I wonder if they extended the oil pick up feed pipe.
Just a thought:)
a litre of oil a day :lol: . it sounds like it used more oil than fuel! :lol:
I was using it as a mini cab when I came out of Army.
Front offside suspension collapsed on the kingswood Roundabout near reigate Hill so I abandoned it.
Not the most ideal car for mini cabbing, especially as i broke down with carberation problems at Clapham south tube during the brixton riots. No one would come out and rescue me:(
