Project Moff - 600BHP R33 GTS-t Skyline
The car is very nearly all set to go on the Dyno in the next day or 2 for a
tweak at Abbey Motorsport on their Dynapack Dyno.
Looking forward to seeing what the car produces...
Should start with a 5 in the BHP figure.. :)
Wow, huge thank sto the guys at Abbey Motorsport...
Project Moff managed 605 BHP at the hubs, which is more power than before, and at less boooooost...
Great results, dyno charts to follow...
RWD only, this is going to be fun... !!!!
Here are the dyno results...
The previous time Mark @ Abbey Motorsport had the car on the Dyno, at 1.5 Bar, the car was producing 594 BHP ATH.
We the changes and improvements we made, he managed to bring the boost in a little earlier, and at 1.4 Bar,
we now have 605 BHP ATH, and what should be a more driveable car too...
Here is the Dyno Graph
For the other dyno sheets, and a comparison of the last ones, for you real geeks, please see :
http://www.theprojectmoff.co.uk/14-may-2013---abbey-motorsport-dyno-results.5487807.cms
Well, what a day...
We managed to end up in 3rd position in the final, and were also faster than the previous club record set in 2011... (guy in first place now holds it, as he was first, but just goes to show how quick the final was)
Photos and more details to follow soon... :)
Huge Thanks to Abbey Motorsport for their help...
  • 3 weeks later...
Engine
RB26 Red painted engine (from an R32 GTR)
Garret 4094R Turbo (Oil and Water Cooled)
HKS F Con Pro Gold Ecu (version 3.2)
Wossner Pistons
PEC Rods
ACL Race Bearings
Stage 1 Abbey Motorsport modified Head
HKS Camshaft 264 Duration - 10.0mm Lift - Inlet
HKS Camshafts 272 Duration -10.2mm Lift - Exhaust.
Balanced Crank, flywheel, front pulley
Top Mount Manifold
Denso 720cc injectors
HKS Oil pump
N1 Water Pump
HKS Gaskets and seals
HKS Triple plate clutch
Greddy External wastegate
Trust 100mm FMIC
Mocal 34 Row Oil Cooler
50mm Japspeed Radiator
Nismo Fuel Pump
Splitfire Coil Packs
Rips modified GTR sump, with diff removed, welded, extended and baffled
Cold start system removed
Cabin heating systems removed from engine
Greddy Fuel Rail
R34 GTR Engine Loom
Greddy EGT Gauge
Greddy Profec B Boost controller
HKS Hard Pipe Kit
K&N Super Huge 100mm intake Filter
Air Con Removed
Carbon Canistor Removed
RB25DET Gearbox
Vibratechnics Custom Race Engine Mounts
Exhaust
Japspeed Silenced De-Cat
V-Band 80mm Turbo Elbow & Downpipe
Japspeed spec 1 cat back exhaust
Drivetrain
Heavy Shockproof Gear Oil
Silkolene Diff Oil
Nismo Pro S 1.5 Way Rear Diff with extended cooling fins
HKS Triple plate Clutch
Suspension
Cusco Front Strut Brace
Cusco Rear Strut Brace
Driftworks Rear Camber and Caster Arms
Cusco Front Camber Arms
Polished Stainless Hicas Lock Bar
Driftworks Front Tie Rods
Tein Track Rod Ends
Tein Track Rods
Poly Subframe Bushes
Driftworks Rear Traction Arms
Ohlin Coilovers (Rebuilt to full track spec)
Exterior
Full Respray (coming soon)
Nismo Bodykit
Custom front Splitter
Carbon Nismo 'B' Pillars
Custom made Carbon Kevlar bonnet
Custom Carbon Kevlar wider front wings
Carbon Rear Boot
Carbon Rear adjustable Spolier
Custom Sand Blasted, etched and powder Coated front and rear subframes
Dual HID's 600k 55w. Main and Dipped Beam
Interior
Tinted Windows
Corbeau Evolution Carbon Kevlar Drivers Seat
Sparco Formula D Suede Steering Wheel
Snap off Steering boss kit
Extended steering boss
Apexi Dual Turbo timer
Greddy Profec B2 Boost Controller
Stripped Interior
HKS Boost Guage
2 x 3" 4 Point EJS Racing Harnesses
Andy Robinson FIA Approved 7 point Roll Cage with Door Bars
Greddy 60mm EGT Gauge
Greddy 60mm Oil temp Guage
Greddy 60mm Oil pressure Guage
Stack Water Temp Gauge
Carbon Door Cards
Brakes
Nismo Steel Brake lines
Stoptech 355mm Front and Rear Discs with Aluminium Hubs
Stoptech 6 Pot Front Calipers
Stoptech 4 Pot Rear Calipers
DS3000 Pads
Custom Moff made brake stopper
RBF600 Racing Brake Fluid
Wheels & Tyres
18 x 11J Rota MXR Rear ET+8
18 x 10J Rota MXR Front ET+12
Toyo 888's 265/30/18 Rear
Toyo 888's 265/35/18 Fronts
Power
At 1.4 Bar Turbo Boost pressure
Peak Power 605 BHP @ 7816 Revs @ Hubs
Peak Torque 445 lb/ft @ 6310 Revs @ Hubs
  • 1 month later...
  • 2 months later...
