CrumbMC Posted April 25, 2013 Posted April 25, 2013 I have looked for some guides on mesh fitting on the internet and most of them say screws. However unless i have screws visibly poking out im not sure how to do it that was. was thinking of maybe using epoxy. does anyone have any reccomedations? the bumper is an EPRacing V2 pics here: Quote
DoogyRev Posted April 25, 2013 Posted April 25, 2013 I used these . . . as long as the area you stick them to is clean they will not come off Quote
CrumbMC Posted April 25, 2013 Author Posted April 25, 2013 thats not a bad idea. i might actually use a glue gun or epoxy with sticky backs. the ones i have for work re only sticky enough for a few 1.5 mm cables. cheers guys. it would be removable with that too Quote
steve916 Posted April 25, 2013 Posted April 25, 2013 I have exactly the same job to do this weekend on my car. Not a zed yet though. I bought some nice stainless mesh that jaguar use Quote
DoogyRev Posted April 25, 2013 Posted April 25, 2013 thats not a bad idea. i might actually use a glue gun or epoxy with sticky backs. the ones i have for work re only sticky enough for a few 1.5 mm cables. cheers guys. it would be removable with that too You can get some "external" ones that will stick like . . . . to a brick Quote
Dizzy Posted April 25, 2013 Posted April 25, 2013 On my westfield I used "sticks like s**t" worked a treat. Quote
14N Posted April 25, 2013 Posted April 25, 2013 (edited) Zmanalex sells a mesh and suggests/supplies some self adhesive clips that work well. On my phone ATM so searching is a little tricky. Bear with me.... EDIT: Found it! : http://www.350z-uk.com/topic/30380-alum-mesh-grills-powdercoated-now-with-clips/ Edited April 25, 2013 by 14N Quote
Mopedmark Posted April 25, 2013 Posted April 25, 2013 Hi guys the best way is clear silicone,I have done about 50 bikes and a few cars for people the key is to use something to put pressure on the mesh but this is the best way. Quote
CrumbMC Posted April 26, 2013 Author Posted April 26, 2013 I went for the sticky tabs, tie wraps and extra glue method. it's also held on quite solidly in the middle where the bumper is strapped between the mesh and my number plate. There's a pic here: http://www.350z-uk.com/topic/70256-nismo-v2-fitted-zeditus-is-taking-hold/page__st__20 Quote
rtbiscuit Posted April 26, 2013 Posted April 26, 2013 The proper way would be to use an epoxy resin and bond either some small ally strips on with holes drilled in the end to take cable ties. Or expoxy on some hard bendy wire that can then be fed through the meek and bent over to hold in place. 1 Quote
rtbiscuit Posted April 26, 2013 Posted April 26, 2013 A fibre glass kit from halfrauds would work a treat. Quote
Mopedmark Posted April 26, 2013 Posted April 26, 2013 Experience, is sometimes good for nothing Quote
mattross1313 Posted April 26, 2013 Posted April 26, 2013 A fibre glass kit from halfrauds would work a treat. Agreed - i fitted mesh to my, and the misses', MR2 Turbo's ages ago. We fitted mesh to the side air intakes - i shaped the mesh around the inner curves and the fibre glassed it into place. Once dry the mesh was not going anywhere!! Quote
CrumbMC Posted April 27, 2013 Author Posted April 27, 2013 Experience, is sometimes good for nothing needed to get it done quick mate. the pads are easily removable. i'll work on it, along with a more legitimate plate next week Quote
