Vortech supercharger pulley sizes
Vortec27
Hi all
As I'm wanting a bit more boost I am thinking of change my pulley size to 3:12 or 2:87 what I need to know is on the v2 sc system is it the tooth cog one I have to change for more boost ?
Ps any links welcome
Thanks vortech
No Mate it's the front ribbed pulley you change down to a 3.12 or 2.87
You can change the toothed pulley setup but most don't.
About 1-2psi increase for each step down.
Watch the jack shaft speeds at less than a 2.87 as they exceed manufactures spec at top rpm
What he said. :D
Ok thanks bros lol. Anyone got any links / part numbers for the pulley that's needed ? Is it the Serpentine-6 Groove, 2.87 in
Thanks vortec
Edited by Vortec27
I use a few suppliers for Vortech parts and local car parts place can get the Gates belts, you could drop Tarmac a PM he may be able to help
Also used these guys but delivery will take a while
http://www.superchargersonline.com/index.php?main_page=index&cPath=510_1071_1073_1305_1310
Also what size belt is needed for 2:87 / 3:12
That depends on your setup, how many pulleys you have and Gen1 or Gen2 -
http://www.superchargersonline.com/index.php?main_page=product_info&cPath=510_1153_1316&products_id=5012
http://www.superchargersonline.com/index.php?main_page=product_info&cPath=510_1153_1316&products_id=5011
Whatever belt you run on with the 3.33 you will need 0.5" shorter for the 2.87 pully (I Think thats correct)
Also are they safe to run on stock block ?
Thanks vortec27
Depends how far you push it, what supporting Mods and who / how it is mapped in, last year I bought a 350z with a blown engine, when we pulled the VQ lump out we found 5 smashed pistons :scare:
That was just running an after market ECU with a bad a map - was really quick ..................................................... until it destroyed itself!
So it's only safe if you do it right!!
Thanks vortec27
Hi mate I think its the 3 pulley setup
Edited by Vortec27
Thanks vortec27
More info plz lol.
so the 93 inch would that be the outer size or iner size for a Gen 1 v2sc ?
Thanks
