Another Engine "KNOCKING" thread VIDEO ADDED 15/11/2012
After searching the forums and online i cannot find anything that matches my symptoms.
On tick over the engine sounds fine.
However when accelerating at around 2500-3000 rpm there is a knocking noise that occurs after this it is not present from what i can hear, i cannot tell if it is something loose, something knocking against something else, engine knock, standard spark knock or just flywheel chatter. i have removed the strut bar air box engine cover to see if this stopped it but no joy i have felt the fuel pressure reg for pulsing and cant say i noticed it pulsing and i have checked oil.
I have fitted a plenum spacer
vs stack mod
ultra lightweight flywheel
Exeddy clutch
Up rev
and always run on premium
any suggestions am i worrying over nothing, do others have this with anything i have fitted.
Edited by rodgeevans
No only the one top drivers side of the plenum. But as i can only get the noise to occur whilst driving i dont know how to replicate it on the drive. I will search for the other fuel regulator, is it easy to get at.
As far as i'm aware the fuel regulators dont knock its more of a tick.
Best thing to do is put a video up, it may help the guys in the know shed some light on it.
Edited by S1 HNK
Right i have recorded a video but need to test the sound quality, what do people use to upload video?. The noise is only present when moving and i can not get the noise to occur when stationary.
right here is the best i could get with my phone hopefully you can hear it clear enough.
So if anyone has any ideas what it is or if it nothing please let me know
So that's what a (nearly) full fuel gauge looks like!
Noise doesn't sound good, but I don't think it could be internals just in that specific rev range. I take it oil pressure is still fine?
Hopefully a heatshield or similar resonating. You really need to pin down the location of the noise as difficult as that is if it only occurs while moving.
i would recommend you get Abbey to have a look at the video
to me it sounds too slow for internals, sounds more exhaust, perhaps manifold. I'm no expert
Cheers guys, yeah the only way i can think to pin down the area of the noise is putting it on a rolling road it sounds like it coming from front N/S which is why i removed airbox and put a cone on it it to check, well i hope you guys are right and its not internals i was convinced it was the engine knocking on the strut bar due to the plenum spacer but then i removed that and the noise was still there im really puzzled.
Lol this is actually how mine looks when full another strange one
:wacko: what are you saying is strange with your fuel guage?
If its the fact it's gone past the full mark - that was the same on both my previous 350's
The fact that its only doing it when you rmoving would lead me to suggest the engines fine, its something vibrating at that particular rpm. Ive had similar problems before and they are a nightmare to try and identify!!! So good luck!!
Oh right i had asked in the past and no one seemed to have seen it before or maybe not that extreme, maybe they just dont fill up the tank, i think i was even accused of doctoring the photo at one point by someone. but least it just not me.
yeah to be honnest the car seems fine, its just annoying, and obviously if it was anything serious best to fix it early before the cost of repairing it goes thru the roof. and would rather work out what it is before splashing cash on more parts, tyres and paint
